My comments are the same for a h pipe. H and x are pretty much the same. The original exhausts are not connected to each other.jonson66 wrote:So what's the point in fitting an x pipe then? By the looks of it everyone is better off with a h?
RS4 B7 stock resonator delete
Re: RS4 B7 stock resonator delete
Ahh I'm with you so the original isn't an H pipe then? What's better then H or original?
There is a theory that an X pipe or H pipe will increase scavenging or something like that with the exhuast gases and give you more power.
I doubt you'd notice the difference though. All the exhaust fabricators I spoke to said they wouldn't bother with it (but i know they are no experts on the subject and probably just wanted an easier exhaust to make). So theoretically a h or x pipe is better but debatable as to whether it is worth it.
I believe it also changes the sound slightly.
What would you say gives the best sound? I've seen vids of yours with the tubi and it sounds epic but the jc weldfab sounds amazing. Not sure if they use a h or x pipe thoughMikeFish wrote:There is a theory that an X pipe or H pipe will increase scavenging or something like that with the exhuast gases and give you more power.
My tubi had a h pipe. I cant say what the difference is like as I changed many things at the same time.
I know Ross did some testing with JCWF on his B8 whici ncluded swapping H for X to see the difference.
For me and the reason I asked was more around not wanting to do a cheap job. I don't want to cut corners to save a few quid, it was not to try and squeeze out extra power.
In that case it is like I said, no x or h pipe will make it the same as it is now. If you are not after power then stick with straight through pipes, no need to complicate it for nothing.jonytek wrote:For me and the reason I asked was more around not wanting to do a cheap job. I don't want to cut corners to save a few quid, it was not to try and squeeze out extra power.
I had a xpipe fitted the other day, sound wise didnt really notice a big change, posted pics of it in another thread.
viewtopic.php?f=35&t=121292#p806649
Seattle-squash
Of course! That would be the only honest thing to do, together with letting them know that someone "stole" my front plate!jonytek wrote:Definitely jumping on this. Are you guys letting your insurance know about this one?
So I cut out the resonator over the weekend and to be honest I was expecting a little bit more. I was expecting more crackle and a deeper tone (valves disconnected).I'll be gutting the precats so we'll see if that makes a difference otherwise I will have to look into a JC Weldfab......
When I finally get one which I will, she will be getting a jc weldfab after weeks of searching for the best lol
You won't regret spending the money on a jc weld, it's awesome
+1!Rw@@dy wrote:You won't regret spending the money on a jc weld, it's awesome
2007 RS4 B7 Avant
Saw your car in there on Friday while I was having mine fitted, looking good mate!FaisalJ wrote:+1!Rw@@dy wrote:You won't regret spending the money on a jc weld, it's awesome
Thanks dude! Looking forward to getting it back tonight!Rw@@dy wrote:Saw your car in there on Friday while I was having mine fitted, looking good mate!FaisalJ wrote:+1!Rw@@dy wrote:You won't regret spending the money on a jc weld, it's awesome
I was driving around the wifey's golf over the weekend, wishing I had my RS back already for the exhaust noise!
In case any of you guys haven't seen it:
https://www.youtube.com/watch?v=65SZXj4fTXA
Also, a couple of clips when the car had a modified OEM system, with precats deleted, an x-pipe, and valves stuck open:
https://www.youtube.com/watch?v=E-Bm-gmEP6E
Hard to pay attention to my car with David's R8 in this vid, but if you listen really really carefully....
https://www.youtube.com/watch?v=vxJwGPXlFE0
2007 RS4 B7 Avant
Users browsing this forum: Google Adsense [Bot] and 166 guests
