Door Trim removal, speaker trim, 6.5's?????
Right first things firts, I am not really sure where to put this post so decided on here in the end...
Car is my RS4 (B5)
Only noticed the other day that whilst my car was being sprayed the lovely chaps at the spray shop managed to snap the speaker grill on the front passenger side. I have allready replaced it one (actually the car hi-fi centre did whilst they were replacing the front speakers).
Anyway I decided to order two normal A4 speaker grills instead of the bose/audi branded covers. I no longer have the BOSE system it was one of the first things to go when I bought the car as it is rubbish.
This afternoon I had 5 minutes so pulled the cracked cover off with ease, it just slid out. I had put JL audio badges on the plain covers as I had the JL audio speaker grills still in the loft. (the only blessing in this whole sorry tail is that I was not sure whether the JL audio badges looked <beep> anyway as they were just stuck onto the grill. on the original JL audio grills they are ressessed in a small indent in the grill)
Anyway came to inserting the new grill and basically it was such a tight fit and without securing it from the rear it kept lifting up and not sitting properly. The drivers side was even more of a joke the car-hi-fi centre had obviously left in on whilst they were doing their bits and pieces and it was welded in place with body filler. I just about managed to free up one of the holes.
I then decided to try and take the door panel off (5 mins was quickly turning into 1 hour, just ask the wife) How the feck do you get that bugger off ? I undid all the screws I could see, even the ones under the handle cover - but it would not move. If someone knows how please enlighten me.
Anyway it was getting colsd anmd I was getting annoyed so went back inside and tried to take a couple of prings off each cover. Wrecked the drivers side by cracking the front cover ( I destroyed the original Bose cover getting it off ) and took 3 prongs off the passenger side so it flaps around in the breeze. Even more annoyed with myself for rushing and wasting £18.00 on speaker grills.
Anyway, my sysytem is pretty good, but the fact that the front speakers are 5.25's is really annoying for that all important mid range, they are the 1st things to go at reasonable volume. Also they tend to go very quickly at mid to low frequency. From having bothe sizes in Corrados I know that the 6.5" will make a massive difference to the listening experience. Hence this seems like a perfect opportunity to upgrade the fronts to 6.5's. I researched this a bit before the initial install and found a company in Germany who make an adapter for the front speakers to take 6.5's. (will post when I find them again) Although I was not sure by the quality, Giles S4RS4 has them in his car, again I am not sure.
I might go for this option, but woindered if anyone else on the list has managed to convert the fronts to 6.5's and if so had di they do it.
I have also added a small pole on what people thing I should do. Either way it is going to be a door off job (please someone tell me how) and definately more than 5 minutes.
Cheers all
Tomson
Car is my RS4 (B5)
Cheers all
Tomson
RE: Door Trim removal, speaker trim, 6.5
Hmm I have found the adapters, made by Phonocar, what are your thoughts people
http://service.winnet.it/phonocar/easys ... /3_715.jpg
Re: RE: Door Trim removal, speaker trim, 6.5
Ignorant when it comes to ICE, so my opinion on that second option purely from a cosmetic point of view:
Don't do it....
I've been thinking what could be worse, and couldn't come up with anything.Tomson wrote: are they crap ???
Don't do it....
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
Back with C6 RS6
And again C7 RS6
RE: Re: RE: Door Trim removal, speaker trim, 6.5
a bit to much pimp my ride for my liking..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
- SimonS4MTM
- Top Gear
I like the ebay ones, do they do a leopard skin finish
- confusionhunter
You obviously like your ICE, so doing work to your doors and not upgrading will probably bug you afterwards and when your mids start flopping.
I would go for the first lot of pods as they look far more OEM and will have better resale value IMHO. The other door pods could turn a lot of people off (including me and I like my ICE too).
Mark.
BRETTCOLLINS
- 5th Gear
Found the adapters to be crap, Wouldn't hold my FOCAL's. so I nice audio friend custom made out of wood and fitted to the inside of panel. Sound was much better.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Car is on Lock down
Yes i might go for the custome route... and build some myself.
So anyone have any old door trims to practice on ? Damaged ones will be fine.
Also anyone with any idea how to get the trim off as yet ?>
- shineydave
doen't the door trim slide upwards once all the screws are removed?
