Nitrogen in car tyres
BRETTCOLLINS
- 5th Gear
Does anyone run Nitrogen in car tyres.
http://www.merityre.co.uk/why_nitrogen.htm
The main advantages of Nitrogen Inflation for tyres are as follows:
1
Tyre Inflation Pressure Remains More Stable
It is normally recommended that tyre pressures should be checked (including the spare tyre) monthly, and before any long trip. With nitrogen inflation, natural pressure loss is less and the interval for adjusting pressures is considerably extended. However, it is naturally still prudent to check your tyre pressures at the recommended intervals and particularly the pressure of any suspect tyre.
2
Condensation On The Inside Of Wheels Is Drastically Reduced
One of the most common everyday problems we face is corrosion on the inside of steel and alloy rims. This leads to leaking around the rim with corresponding suspicion of a slow puncture.The introduction of nitrogen inside the tyre prevents oxidization which causes a rapid ageing of the tyre and corrosion inside the rim.
3
The Possibility Of A Blow Out Or Explosion Is Reduced
Nitrogen doesn't heat up like oxygen, the tyre therefore runs cooler and thus reduces the possibility of explosion.
4
Better Grip On The Road
Nitrogen being far more stable in respect of temperature and pressure translates into better grip and improved vehicle handling. There are also proven reports of extended tyre life, making nitrogen inflation very cost effective. In addition to the benefits for most road users, nitrogen inflation has particular benfits for caravan, camper and trailer users. Better pressure retention and a reduction in the ageing process are real benefits for these vehicles which often spend a great deal of time standing in one place.
1
2
3
4
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Car is on Lock down
RE: Nitrogen in car tyres
my dad has his tyres filled with this stuff and he swears by it..and he,s 77...
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
I check my tyres and pressures regulary. The way I look at it I'd be letting out Nitrogen all the time and be putting air in. I've therefore never bothered.
B8 A4 Avant quattro
Honda CBR1100XX Super Blackbird
Suzuki GSXR1000 (Track bike)
B6 S4 (AMD Stage 3) - GONE
8N TT (APR/AMD/MTM) - GONE
- shineydave
i run nitrogen and to be fair if the pressures are set right from the outset you shouldn't need to top them up as the nitrogen molecules are larger than air and so don't leak as readily
Dave
What I was getting at is that evert time you check them you get a little come out. I also find that with Goodyear F1's they need adjusting with the temperature of the weather, hence I'm always putting it in or taking it out.
B8 A4 Avant quattro
Hi Dave,
Where do you go for your Nitro or have you a nice big cylinder in the back yard?
cheers
Darren
cheers
Darren
99 FL, Reflex Silver, H&R Coilovers and ARBs, AWE DTS, Miltek Duel Cat Back, Hyperboost DVs, Autometer Boost Guage, RS4 18" Reps, Tanoga SS, Lecky SR, Nappa, Bose, Cruise, Phatnoise, MRC Custom remap, RS246 Sticker.
- shineydave
you can get it from National tyres
Dave
- Ruical
Scotty,I also find that with Goodyear F1's they need adjusting with the temperature of the weather
When i replaced my Bridgestones, my local garage filled the new F1's with nitrogen, and i have noticed that the pressure does not fluctuate much at all. Never had them on normal air, so cannot comment on the pressure fluctuations. Might be worth a try yourself though, as a wee experiment
They also said it is their standard policy to fill all new/replacement tyres with nitrogen.
Users browsing this forum: No registered users and 46 guests
