Removing fog lamps
Removing fog lamps
Some of you RS4 chaps have removed your fog lamps havent you? is this to help cool the brakes?
SitaS3 and I were comparing the heat of his new calipers yesterday after a slow run up the road - god knows what they must get like on the track [img]images/graemlins/blush.gif[/img]
It got us discussing removing the fog lamps - I never use mine...
Dunc [img]images/graemlins/s3addict.gif[/img]
Re: Removing fog lamps
Hey Dunc, we've removed the fogs on our RS4's (and S4's) to give a better flow of air over the intercoolers - car performs much better on trackdays [img]images/graemlins/wink.gif[/img]
Not sure on the position of yours, but I know you have the vents (like us) in the inner wheel arch, which if opened up could improve airflow to the brakes - let us know how you get on [img]images/graemlins/thumbs.gif[/img]
Andiroo
Andiroo
Previous :RS4 B5 (Noggy Babe), 934 GT2, 996 Cup.
WIP :to be advised.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008 **And how it died on it's arse**
Arn't the RS4 and S4 fogs mounted behind the grill in the bumper...
not in the grill like the S3.
not so easy for us Dunc, cosmetically speaking.
it would be better if we could move the intercoolers - maybe combine into a single front mounted one. Problem with our cars (S3) is that the air moves through the intercoolers, then thru the vents Andy's talking about - by which time the airflow is restricted (and warm...) - also a further problem is lack of space up front.
Did you notice how hot the wheel was Dunc? i did and I shall be monitoring this.. Cars - one bloody thing after another. [img]images/graemlins/rocketwhore.gif[/img]
M3 CSL - Silver Grey, a few options.
I've also read that a front mounted i/c helps to prevent pressure drop between the turbo and engine.
ChrisG
can you get a FMIC for the S3? I know you can for the TT...
failing that, lets all move to Iceland
after you, then..
btw, i know AMD were talking about a fmic for the S3, but maybe also take a look at Star Performance - they even do one for the Golf 1.8T
Go on, your turn to spend some money.
LittleSkull
Forge and Stratmosphere make the FMIC for the TT 225hp (see attachment) so maybe they have them for the S3.
