audi specialists
audi specialists
After months and months of looking at rs4's to replace my ageing e34 M5 I finally took the plunge, took out a loan, and promptly spent it on a 52 plate, ebony black rs6 avant.
Problem is the car's warranty has now expired, I don't want to renew it and I'd rather pay specialist rates than stealership rates when any work needs doing. Does anyone know of a good specialist within a 50 mile radius of sheffield?
Thanks in advance.
Thanks in advance.
RE: audi specialists
Is that the emg performance one ?
Keith
Keith
Nope. It's from an independant called Specialist Cars near Selby.KeithD wrote:Is that the emg performance one ?
Keith
They said they would be happy to do any work needed in the future, but they usually work on porsche, ferrari and bmw M-power cars.
I really need someone who has experience of replacing the dampers as it feels as though the NSR may be on the way out.
I would consider getting an extended warranty.
The dampers on RS6's are know to weep/fail. Do a search and you will find it and how much it might cost. You might find the warranty doesn't cost much more and you'll then be covered for other things.
Mine is in at the mo having the Sat Nav replaced and front dampers refilled. The cost of this alone is more than the warranty fee.
I did briefly consider the extended warranty but as it's already 3 months out of the warranty period and appears to have this suspension problem would I be eligible to renew?
I assumed the car would have to be inspected and deemed to be perfect prior to audi allowing me to take out the warranty?
Might be worth a try, they may not spot it. As long as the inspection is done beforre you hand over money you've got nothing to loose.
If you go independant my personal recommendation is a little further for you, but very experienced ex-Audi and AmD techs www.autops.co.uk
- harry
You should be ok to renew warranty. Only if it expires 10 months or more are they sceptical to renew IIRC. Its not your fault its expired as you've just bought the car so shouldn't be penalised.it's already 3 months out of the warranty period
Practise safe sex & drive a hybrid if you can...
- harry
Warranty is like paying up front for man hours if a warrantable component fails or needs replaced PLUS they cover the cost of an entire new engine if it lets go. So it works like an insurance policy, gives you peace of mind, avoids additional unexpected costs and if theI don't want to renew it and I'd rather pay specialist rates than stealership rates when any work needs doing.
Congrats on yer new ride by the way! Audi/RS ownership is a mutual appreciation society. Look after yourself and each other.
- harry
Hasnt happened to me so far. Anyone else had experience of this?I assumed the car would have to be inspected and deemed to be perfect prior to audi allowing me to take out the warranty?
- harry
Can I modify that to Audi/S/RS so as not to offend anyone by leaving them out.Audi/RS ownership is a mutual appreciation society
Thankyou.
Thanks for all the advice.
Contacted my main dealer about renewing the warranty. They informed me that as the warranty had lapsed it would be about 350 dearer at 1907 for the year, plus 105 for the pre-warranty inspection.
I think this may need a bit of thought.
Other than the dampers are there any other common warranty issues?
That sounds like a feck of a lot, I'd try somewhere else. Lots of third party ones around, don't know how you'd get on with Mondial (which is what Audi use and put their name on it) if you approached them directly. Anyway, I have two years warranty with Listers Audi, who have their 'own' policy. They are considered very RS savvy and have a good reputation, maybe worth a call. They've just sold me my RS6+, and you could give them a call and speak to Claire Garness if you like, mention my name by all means. 01905 421000
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
Back with C6 RS6
And again C7 RS6
- harry
I would really argue the toss here considering your position buying a preloved car and get them to confirm their policy on lapsed warranty issues with you perhaps through HQ customer services.They informed me that as the warranty had lapsed it would be about 350 dearer at 1907 for the year, plus 105 for the pre-warranty inspection
Also be careful when considering other policies that you are comparing apples with apples.
Re the damper issue, my car has just had these changed and comes out of warranty in May. I was told by the tech that the official line from Audi is that there is no design fault with the dampers, but they are providing goodwill gestures for out of warranty cars
