remote opening - keys
2.7 V6 30v biturbo - 380 bhp
matcook2005
Post by matcook2005 » Sun Feb 19, 2006 6:30 pm
anyone suffering key forgetting car syndrome
after about half a day my key stops talking to the car, i re train it and then it forgets the next day
solutions?
shineydave
RE: remote opening - keys
Post by shineydave » Sun Feb 19, 2006 8:11 pm
Battery on it's last legs maybe?
Dave
Golich
Post by Golich » Mon Feb 20, 2006 9:19 pm
What do you mean you re-train it?
matcook2005
bloody key
Post by matcook2005 » Mon Feb 20, 2006 10:18 pm
changed batteries
retrain means if you put the key in the drivers door and hold it open the car resends the info to the key. thus it works but mine seems to have alzheimers
ta
PaulR
RE: bloody key
Post by PaulR » Thu Feb 23, 2006 4:34 pm
I dropped mine in a bucket of water without any memory loss! Very carefully dried it out and still all seems well. Couldn't believe my luck. But I will remember the tip in case I have problems. Is that a process you need to go through when changing batteries in the remote?
...Paul.
harry
RE: bloody key
Post by harry » Thu Feb 23, 2006 4:37 pm
No you have to take all keys including the skeleton to the dealer so they can reprogramme the lot on a computer thingy?
Wait a minute - is that Vag Com by any chance?
Practise safe sex & drive a hybrid if you can...
Nige_RS4
RE: bloody key
Post by Nige_RS4 » Thu Feb 23, 2006 4:40 pm
I thought the procedure for retraining a key was as described above - this should include changing batteries?
harry
RE: bloody key
Post by harry » Thu Feb 23, 2006 4:47 pm
Am led to believe that if you change the battery on one then the others cant communicate with it/the car therefore have to all be reprogrammed. No mention of the door retraining thing from the dealer.
Or id thid just another money making exercise from them???
Nige_RS4
RE: bloody key
Post by Nige_RS4 » Thu Feb 23, 2006 5:04 pm
simple1
RE: bloody key
Post by simple1 » Thu Feb 23, 2006 9:17 pm
keys programming is quite complicated and has to be done by the dealer, it involves a process which needs the dealer to contact Germany with chassis number to obtain access codes........ long drawn out and and expensive...............
shineydave
Re: RE: bloody key
Post by shineydave » Thu Feb 23, 2006 9:27 pm
simple1 wrote:keys programming is quite complicated and has to be done by the dealer, it involves a process which needs the dealer to contact Germany with chassis number to obtain access codes........ long drawn out and and expensive...............
that's if you're adding a new key with a different transponder for the immobiliser. to reprogram just the remote part you can follow the procedure of putting the key in the door, unlocking it manually then holding down the unlock button
Dave
tombs
RE: Re: RE: bloody key
Post by tombs » Thu Feb 23, 2006 10:02 pm
Shiney's right, I changed the battery on mine and followed this procedure. ...easy
derdle
Post by derdle » Fri Feb 24, 2006 11:28 am
I changed the batteries in both my keys (one key at a time) and all was well.
As for the original problem, perhaps VagCom would show a fault on the car somewhere?
Paul
RS4 in the only colour to have - Misano Red | MRC Remap | RS6+ brakes | H&R and Custom Performance Parts suspension |
Huge Grin :biggrin3: If you dont "do it now" you never will.
harry
Post by harry » Fri Feb 24, 2006 8:23 pm
so i've been ripped off then to the tune of twenty odd quid by - thats right you guessed it people - the stealership :evil:
shineydave
Post by shineydave » Fri Feb 24, 2006 8:55 pm
it's a complicated procedure
1. insert key into door and turn to unlock
2. press unlock button on remote
3. undo clients trousers
4. administer severe rodgering in a manner which is illigal in 49 states
5. extract £20 from clients wallet
6. kiss the client (most people like to get kissed when they get f**ked)
Dave
Users browsing this forum: No registered users and 184 guests
