Engine removal YouTube video
pwack
Post by pwack » Sun Feb 16, 2025 6:36 pm
Superron has just released a video on YouTube which involves removing the engine from an RS6 for some work ,decent detailed vid if you are looking at taking the engine out yourself.
https://youtu.be/-w-GWiXapAI?si=iyTeXME8FfKFHgoQ
srichards
Re: Engine removal YouTube video
Post by srichards » Mon Feb 17, 2025 8:29 am
I watched that other night and felt a little light headed! I can see why a lot of garages won't work on these.
After watching it I'm 100% certain I wouldn't do it myself :biggrin3:
Felix2566
Post by Felix2566 » Mon Feb 17, 2025 11:03 am
Cheers, will give it a watch. Will be doing a manual conversion on mine this year....
AWT
Post by AWT » Tue Feb 18, 2025 7:06 pm
I just did that on mine this weekend and let me tell you, I would rather brake it for parts than do ot again :?
Felix2566
Post by Felix2566 » Tue Feb 18, 2025 10:14 pm
Really, why was it so bad?
AWT
Post by AWT » Tue Feb 18, 2025 10:28 pm
Seized bolts,pipes, everything old and fragile... I had to cut the oil cooler lines to remove them to avoid damaging thread on oil cooler, every bolt holding exhaust/turbo/manifold had to be heated up with flame.... Luckily, all O rings still can be ordered in Audi. Gearbox sent to repair, turbos, tomorow tooth belt and everything that goes with it, chain tensioner shoes, brake calipers refurbish....list goes on and on and on....
srichards
Post by srichards » Sat Feb 22, 2025 10:16 am
Next one has gone live. Blimey. Seems like TPS can get everything so far that is needed so that's good. I'm now wondering what condition mine would have been had it been taken to bits!
https://www.youtube.com/watch?v=y0dwDjY9pOg
Steve2003rs6
Post by Steve2003rs6 » Tue Feb 25, 2025 10:05 pm
Brilliant videos. Very informative.
Just watched the super Ron video Hats off to anyone that diy this job.
No way would I attempt that.
However if you are capable and you do it yourself. At least you know it’s been done properly and handled with care.
Ps. What a crap exhaust manifold design.
srichards
Post by srichards » Sat Mar 01, 2025 12:17 am
Part 3.
This is mostly mending a lot of the issues. Cam tensioners are interesting looking units. Sliders seem to get grooved and chewed. I'm assuming the black plastic pipe right inside the engine is the Bufkin. Also features the classic bastard bolt.
https://www.youtube.com/watch?v=l2qAivyjKDU&t=0s
111marc111
Post by 111marc111 » Sat Mar 01, 2025 1:38 am
This set of videos has come literally 6months just too late for me! He's pretty much done exactly what im pretty much finished up doing now. So informative.
Felix2566
Post by Felix2566 » Sat Mar 01, 2025 10:17 am
Yes am really enjoying watching them. Perfect heads up on what I have to look forward to. Non of it looks especially hard once the engine is out.
Well worth doing all the preventative stuff once it's out the car
Mɐʇʇ
Post by Mɐʇʇ » Tue Mar 04, 2025 11:48 pm
It’s not “that” bad. I removed mine 3 times on axle stands in my garage. There’s a lot to undo etc, but just follow the service manual and you’ll be fine. Used to take me a day to get the engine and box out. Could have done it quicker on a lift, I am sure.
srichards
Post by srichards » Sat Mar 08, 2025 8:57 am
Next video available. Turbo rebuilds didn't go as easily as hoped. Managed to get all the parts needed again. Lots of the pulleys are after market as NLA by audi. EGTs are right on the back and inaccessible with engine in. One of the lambdas also if my single brain cell has remembered correctly. Other lambda you can get at from underneath I think.
https://www.youtube.com/watch?v=gk5w4wT4e3U
srichards
Post by srichards » Sat Mar 29, 2025 8:12 am
Final part. It all goes back in. The dodgy bit of wiring was for the SAI as there is a block of wiring under a cover that you can't get back in if you take it out. Didn't know there were little grommet cut offs in the bulk head so you can pass new wires through without chewing up other things.
If you are going to do it then the instructions in the manual he links to are essential for a having a hope in hell of getting it apart and back together correctly.
https://www.youtube.com/watch?v=rXOfjMEqQ6g
Steve2003rs6
Post by Steve2003rs6 » Sat Mar 29, 2025 12:16 pm
Cracking videos.
I have watched them a few times now.
Users browsing this forum: asgor and 100 guests
