hi ,
had to use TMS stuff in boot as had nasty puncture today .
has anyone had to replace it before ??
should i buy another bottle from audi or best to source elsewhere ?
any help would be greatly appreciated
Chris RS6 avant
tire mobility system
it worked a treat , took the valve out and let what little air their was out and really had to squeeze it in hard , blew it up with the compressor to 36psi then drove it on and off the drive .
did this in the afternoon and 24hrs later it was still up no problem when i had the tyre replaced as it was low tread anyway.
one thing to note it took them a while to get the tyre off as the gluey stuff had set solid , so yes its good , but for a simple puncture it may not be possible to repair when you use the TMS in the boot
picked a new bottle up from audi , took 24hrs to get and cost £30 .
Chris
Chris
- SimonS4MTM
- Top Gear
- SimonS4MTM
- Top Gear
thats because you did not set nominal presures correctly.
http://www.beru.com/download/produkte/k ... _tss_e.pdf
i emailed this link to the crew a long time ago, they obviously did not think it worth while to post it
Users browsing this forum: Google [Bot], skyegtb and 69 guests
