I know this is well out of normal spec but the engine starts on the button, idles fine and there are no rattles or strange noises coming from the engine at all, I believe it is due a cam belt anyway but i am just wondering if this value would be closer to 0 deg once the belt is changed and cam sprockets reset, i was also wondering if this could anyway effect boost? as i don't have any at all lol, would the fact that the timing is that retarded mean that the ecu can't utilise the VVT causing the car to be in "Limp mode" and restricting the performance,
I have no ecu fault codes at all at the moment and the car doesn't feel too sluggish, just feels like a normally aspirated V8,
I will look at all the parts required for changing the belt and see what the figures are like after its all replaced, I know these figures are usually signs that the chains or tensioners require replacing but as there are no rattles and the chains and tensioners look to be in good condition i just wondered if the belt could be the culprit. Just wanted some advice from people in the know,
