Breakdown
steve2003rs6
Re: Breakdown
Post by steve2003rs6 » Mon Nov 11, 2024 12:25 pm
Car used to start as soon as you turned the key first time every time.
Now takes two to three attempts before she fires up. Seems worse from cold start.
Once she has fired up she drives like normal.
However just pleased that the car is useable again.
Re: Breakdown
Post by Shoppinit » Mon Nov 11, 2024 12:32 pm
Might be a small air leak in the fuel lines causing the pump to take time to build up to pressure. It’s been messed with a fair amount recently.
Try turning the key to position II for a few seconds then off. Do that a couple of time before starting.
Or maybe you’ve got a fuel pressure regulator problem. That could have hastened the demise of the fuel pump(s).
Re: Breakdown
Post by Shoppinit » Mon Nov 11, 2024 12:33 pm
Check to see what your coolant temp sender is reading before starting.
steve2003rs6
Re: Breakdown
Post by steve2003rs6 » Mon Nov 11, 2024 1:10 pm
Hi Ben.
Will do. However the coolant temp sensor was replaced not too long ago. G62
No error codes on VCDS.
steve2003rs6
Re: Breakdown
Post by steve2003rs6 » Mon Nov 11, 2024 7:28 pm
I reckon this is the problem Ben. Once it’s started it’s ok. If I immediately start it after switching off it’s still ok. However if I leave it for a while then it’s back to two or three attempts to get it to fire up.
I have a fuel pressure regulator on order from Autodoc. Should get it this week.
steve2003rs6
Re: Breakdown
Post by steve2003rs6 » Mon Nov 11, 2024 8:37 pm
Been to the shops for a Chinese takeaway. Parked up in the car park.
On return I couldn’t help but admire the car on her stunning looks. It doesn’t matter what angle you view the car from, they just stand out from the norm.
That may be helped by the fact that I had the car cleaned and waxed this morning.
Even after 12 years of ownership I am still a very proud owner of one of these amazing cars.
Marcin
Re: Breakdown
Post by Marcin » Tue Nov 12, 2024 10:32 am
I get the same feeling each time :kissmyrings:
Is:
2003 RS6 | 2013 A6 BiTDI quattro | 2016 Corsa ;) | Suzuki GSX-R 1000 K6
was:
2004 A6 3.0TDI quattro | 2000 A6 1.8T quattro | 1997 A6 1.8 | 1998 Opel Vectra 1.6 | 1985 VW Santana |
TOPMAN
Re: Breakdown
Post by TOPMAN » Thu Nov 14, 2024 12:46 pm
This is one of the longest threads on this forum
Users browsing this forum: srichards and 117 guests
