Continuing gearbox, not quite perfect.
philS2
Post by philS2 » Tue Jul 30, 2024 12:42 pm
After replacing oil tube 0501 315 340, (with amazing guidance from Shop) my second gear "flaring revs" and slamming gears have all but disappeared.
It still doesn't accelerate properly in second though, (third actually pulls better), so I'm going to get whichever oil tube is the next contender.
Does anyone know if 0501 315 341,
0501 315 342,
0501 315 343 or
0501 315 344, is the next favourite?
I've got prices from EXB, and I'll replace the lot, if need be.
Cheers, Phil.
Re: Continuing gearbox, not quite perfect.
Post by Shoppinit » Tue Jul 30, 2024 4:16 pm
I think I'd just do the lot. In for a penny...
srichards
Post by srichards » Tue Jul 30, 2024 4:23 pm
If you don't do all of them the law of sod will dictate whichever you don't do will decide to misbehave once you've put it all back together anyway....
philS2
Post by philS2 » Tue Jul 30, 2024 10:32 pm
Righty o. That's decided then. Almost perfect gearbox, here I come.(I'm going to be realistic here)😀
Post by Shoppinit » Wed Jul 31, 2024 7:59 am
It might be worth checking the valve body over for wear first. Some of the little springs and ball valves.
Felix2566
Post by Felix2566 » Wed Jul 31, 2024 5:38 pm
Have you inspected the filter, where it attaches to the gearbox. My mate had the same symptoms, replaced the pipes etc, was on a very new box too, turned out the filter body had a crack in it, pump must have been drawing in some air.
philS2
Post by philS2 » Thu Aug 01, 2024 12:11 am
Cheers for the replies.
I changed the oil and filter myself when I bought the car in 2016.
Made no difference.
And I'm guessing, again in 2019 when it had torque converter, clutch packs and seals.
Still, the revs flared in second and was slow to change gear.
I put a tested valve body on in 2020/21.
No difference.
Then I changed the smallest oil pipe and it cured the second gear slip by 95%.
When I get someone to fit these pioes, it'll obviously have another filter, so either way (fingers crossed) it should be as good as new..
Felix2566
Post by Felix2566 » Thu Aug 01, 2024 10:08 am
Fingers crossed that fixes it all.
philS2
Post by philS2 » Thu Oct 31, 2024 9:02 pm
<beep>. Just finished changing all 5 pipes and used the ZF fluid change kit.
Complete with instructions.
I followed the filling procedure for just a fluid change (I also did that when I replace just one pipe a while ago).
There was smoke coming from the fill hole, not long after initial fill and start up, and it smelled burnt. (Can't remember if that happened before).
No funny noises though.
It took all 7 litres of lifeguard 5 and still needs more.
Which I guess i should have known.
No starvation, even when i lowered the front end down and drove it off the ramps.
And now.... it goes forward in reverse. Bollox.
No codes and drives well through the gears.
It seems doomed.
Any ideas would be welcome, cheers.
philS2
Post by philS2 » Thu Oct 31, 2024 9:22 pm
Just read a piece on Gears website and it all make so much sense, NOW.
Pretty sure either pump or converter is literally, toast.
Post by Shoppinit » Thu Oct 31, 2024 9:42 pm
What’s the diagnosis?
philS2
Post by philS2 » Thu Oct 31, 2024 10:23 pm
Still not sure. I'm (clutching at straws) going to activate the solenoids tomorrow and also make sure the shifter matches what VCDS says.
Seems strange that it drives in all forward gears, although, presumably, reverse might have took the hit on dry, intial start up.
If that's possible.
philS2
Post by philS2 » Fri Nov 01, 2024 10:16 am
There's at least one click from all available solenoids.
F125 reports
P 1000
R 0100
N 1110
D 1011
S 0111
Solenoid 1,2 and 3 read O
Pressure control valves and TCC - 0.048A
TC open on idle.
When turning off engine in park there is a lurch forward.
So, just a heads up to anyone doing work to their trans and draining more than a fluid change amount.
Looks like there needs to be instant fluid refill and possibly going through and holding the gears on initial start up.
There's obviously a ZF procedure for a dry trans, but it's too late for me.
Post by Shoppinit » Fri Nov 01, 2024 11:16 am
Arse. You think the damage is done?
Could you have misaligned the atf pump when installing?
philS2
Post by philS2 » Fri Nov 01, 2024 12:18 pm
I really do.
I only dropped the valve body, to replace the pipes.
I'm guessing it's not incorporated into that?
I didn't (and couldn't see a way) to remove the F125 shaft that spans the width of the transmission.
I had to bend the old pipes to get them out passed it.
Then pooping myself, do the same to the new ones.
Nothing too severe.
Just gentle curves.
I think the smoke that started a few seconds after start up speaks volumes.
Users browsing this forum: audirew, Google [Bot] and 94 guests
