Cooling fans
cover99
Cooling fans
Post by cover99 » Sat Sep 28, 2024 7:21 pm
Evening all.
I have noticed the following recently.
When car is started from cold, my coolant temp is low as is the oil temperature.
My cooling fans are coming on with air con off at this point. Coolant and oil temp eventually come up to normal levels on the dash.
Fans are controlling as ramping up and down. Not just on constantly.
Not sure if this is normal or not but don’t remember this in the past when starting her up.
Anyone had this before?
Thanks Steven
TOPMAN
Re: Cooling fans
Post by TOPMAN » Sat Sep 28, 2024 8:41 pm
Is the ECON light lit?
cover99
Re: Cooling fans
Post by cover99 » Sat Sep 28, 2024 8:53 pm
Yes the Econ light is on.
TOPMAN
Re: Cooling fans
Post by TOPMAN » Sat Sep 28, 2024 9:41 pm
Check the connection to the high pressure switch (circled). My plug was loose causing the same problems you describe. Bodged it with cable ties as shown.
cover99
Re: Cooling fans
Post by cover99 » Sat Sep 28, 2024 10:04 pm
I will have a check.much appreciated
Users browsing this forum: No registered users and 125 guests
