Gearbox Sump Pan
GTI-C5RS6
Gearbox Sump Pan
Post by GTI-C5RS6 » Thu Sep 12, 2024 11:27 am
Can anyone help me with where to buy a new gearbox sump pan for my C5 RS6. My gearbox went into limp mode, checked underneath and looks like the sump has taken a knock and is leaking. I'm hoping a new sump and refill of fluid will resolve my issue.
I was told that as the gearbox is "sealed for life", the service kit comes with a new sump, but from the photos it looks like this is just a filter. Is that correct?
thanks in advance
Felix2566
Re: Gearbox Sump Pan
Post by Felix2566 » Thu Sep 12, 2024 1:20 pm
Service kit is a new filter, but these boxes, the filter is seperate to the sump.
The sump part number is 01L321359C. There are enough cars being broken on Ebay and faceache, some probably due to the made of cheese gearbox. Shouldnt be too hard to get a sump
Post by Shoppinit » Thu Sep 12, 2024 1:27 pm
Be careful that you get the right filter. The RS6 one has a shorter pickup pipe. If you get the wrong one it will touch the sump and prevent free ingress of ATF causing much woe.
GTI-C5RS6
Post by GTI-C5RS6 » Thu Sep 12, 2024 2:59 pm
Thanks guys, I've messaged a few of breakers on ebay/Facebook, seems most are only sold with the gearbox. If anyone hears of/has one going I would be very grateful!
Post by Shoppinit » Thu Sep 12, 2024 4:12 pm
Can’t yours be persuaded back into shape?
GTI-C5RS6
Post by GTI-C5RS6 » Fri Sep 13, 2024 9:24 am
I'm going to try get it all apart next week and see if it can be salvaged, will get some photos
Mɐʇʇ
Post by Mɐʇʇ » Fri Sep 13, 2024 6:07 pm
IIRC ChrisA might have a spare
steve2003rs6
Post by steve2003rs6 » Fri Sep 13, 2024 7:16 pm
Is that the one I sent you Matt ?
Nice to hear from you mate.
GTI-C5RS6
Post by GTI-C5RS6 » Tue Nov 05, 2024 12:01 am
Thanks for suggestions guys. If anyone needs one of these, I ended up having to buy a new sump. Found one from a company called Vanmatic. Looks to be direct from ZF, no Audi part numbers or stamps on the pan but was all I could find!
https://www.vanmatic.com/parts/hp/zf5hp ... --56-hp-82
All fitted now and appears to have sorted my problem, back to running sweet (touch wood). I was worried I needed another gearbox rebuild after only 25k miles since the last one in 2014. I’m no expert, but for anyone with an incorrect gear ratio fault code 17119 on Vagcom, it’s worth checking transmission fluid level.
GTI-C5RS6
Post by GTI-C5RS6 » Tue Nov 05, 2024 12:24 am
Fingers crossed for some more trouble free years
srichards
Post by srichards » Tue Nov 05, 2024 8:55 am
Link saved just in case!
Also the F125 transmission range switch is a consumable by the look of it and often the cause of any weird behaviour that a gearbox service doesn't sort out.
Post by Shoppinit » Tue Nov 05, 2024 9:26 am
Yeah, I've got 3 spare on my shelf now.
Felix2566
Post by Felix2566 » Tue Nov 05, 2024 9:58 am
Awesome colour for an avant, glad it's back to full health!
Users browsing this forum: MeTsU, Shoppinit and 56 guests
