Steering wheel plus mirror question
stevo55
Re: Steering wheel plus mirror question
Post by stevo55 » Thu Jul 11, 2024 6:51 pm
Shoppinit wrote:I’d be surprised if they had a different harness. Maybe you need to code the steering wheel module to tell it it’s got buttons. What’s your current coding?
Good point and it’s back from the garage now-will call them tomorrow but failing that she’s in for a service and other bits next week at a specialist so they should be able to assist.
Annoying though.
Current:
Former:
2016 R8 V10 Plus.
2019 E63s AMG 4Matic Estate.
2017 BMW M3 Competition Pack.
2015 A45 AMG.Overrated POS.
2016 C7 RS6 Panther black.
2006 BMW Z4M Roadster.
2004 Alpina Roadster.
1994 E34 M5 Saloon
stevo55
Post by stevo55 » Fri Jul 12, 2024 9:54 am
Just spoke to the garage again and they said there was a connector for the airbag and that was it. Ref coding they said they can’t code anything through thin air as there were no physical connectors to plug into the new wheel.
Confused.com here so will push this to local specialist as there must be a fix-it’s an OEM RS6 item for that car.
Current:
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
TOPMAN
Post by TOPMAN » Fri Jul 12, 2024 10:43 am
I’m quite sure that you have the wrong clock spring. You need part number 1J0959654AL according to ETKA which has extra connectors for heating the wheel. Look at this photo I found, it has 3 connectors. Airbag, tip and temp sensor (I believe). There is also an extra connector in the top right corner which I believe powers the heating element (not in photo).
From memory I recall that there is also a small harness to power the heating element.
You will also need the control unit for the MSFW with tip function, if you haven’t got it already. VCDS shows mine as part number 4B0 907 487 H. About 15 years ago someone did a detailed write up on this retrofit, but I can’t find it right now.
stevo55
Post by stevo55 » Fri Jul 12, 2024 11:52 am
Aha. So it looks like the spare I have is an ‘AC’ as opposed to an ‘AL’ which is typical.
Quick search shows how expensive they are-pushing £400! Ouch.
One thing I guess is I have to of the ‘AC’s’ that I could sell (including the one off the current fitted wheel) but it’s still a major faff. What a surprise. Not.
Also the control unit you mention-where does that plug into? Unfortunately I have no way of knowing if the steering wheel is a heated one (am guessing the heating elements are inside the wheel) and there was no serial number to go off and it’s now on the car.
Many Thanks for the info though! Very helpful
Current:
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
Users browsing this forum: No registered users and 105 guests
