N80 valve
N80 valve
I think my n80 is faulty as i am getting a 16825 code. So I have taken it off an run power to where it clicks once if you reverse the terminals it clicks once again but I thought with a constant feed the n80 would open and close continously.
Re: N80 valve
It’s just a solenoid valve IIRC. If you want to test it you can use the output tests with the Vagcom.
Users browsing this forum: Bing [Bot] and 97 guests
