Post your Rolling Road Results Here
lugars4
Post by lugars4 » Sat Mar 23, 2024 9:26 pm
Couldnt see a thread of shared results.
Interested in the torque profiles of different cars / tuner maps.
For reference, this is the standard torque curve from the brochure.
This is a bit of data i found on how someone had tested the flap openings, throttle opening v.s RPM etc. Interesting plot.
This is mine pre-cleaning. Notice the torque falling off from 4000rpm when it should start picking up.
I also had a stuck air box flap on this test.
06 - B7 RS4 Saloon - Milltek Non-Res Valved. BMC Filter.
12th
Re: Post your Rolling Road Results Here
Post by 12th » Sun Mar 24, 2024 9:38 am
I can't seem to copy a pdf to add here.
Sprint Blue B7 RS4 Saloon with MRC tweakery.
lugars4
Post by lugars4 » Mon Mar 25, 2024 10:52 pm
Should allow you on the attachment section when making a new post. Make sure you are in full / advanced post mode.
Look forward to seeing some results.
JRC1
Post by JRC1 » Tue Mar 26, 2024 12:05 am
Here’s mine. Before and after carbon clean, decat downpipes and Stage 2 tune at MRC.
12th
Post by 12th » Tue Mar 26, 2024 8:58 am
The only 'add image' icon I can see seems designed for weblinks only.
MRC dyno results.pdf
(425.76 KiB) Downloaded 35 times
Tried dragging and dropping and using the attachment tab at the bottom - doesn't seem to work for me.
JamesBaby
Post by JamesBaby » Wed Mar 27, 2024 10:11 am
I converted it to Jpeg for you.
12th
Post by 12th » Wed Mar 27, 2024 10:13 am
Many thanks!
Wheels refurnished last year and some small bits of corrosion being attended to this month - still intend to get the leather tidied up a little (it's in pretty good nick, but the car's a keeper) and have an aftermarket exhaust added.
Users browsing this forum: Bing [Bot] and 81 guests
