Oil spraying from filler cap!!!
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
DavidT
RE: Oil spraying from filler cap!!!
Post by DavidT » Sun Feb 12, 2006 3:48 pm
It was a private sale
Dunc, I'm not sure what comeback there is on the dealer based on this?
Ryan_s3
Post by Ryan_s3 » Sun Feb 12, 2006 4:08 pm
Bloody plugs again!
If i were you mate ,i'd source a 2nd hand 1.8t engine and fit that instead of messing about.
Image360bhp 342lb/t
DuncS3
Post by DuncS3 » Sun Feb 12, 2006 4:22 pm
I meant Audi CS - just as a minimum to see what they say
DavidT
Post by DavidT » Sun Feb 12, 2006 6:52 pm
DuncS3 wrote:I meant Audi CS - just as a minimum to see what they say
I'm with you now mate, sorry.
Engine swap is the most straighforward. It might be worth ringing round the Audi Breakers to see what's around ?
BlackS3
Post by BlackS3 » Mon Feb 13, 2006 12:58 pm
Thanks for the comments guys! If anyone can recommend companies etc to source parts and maybe another engine all help would be much appreciated. As soon as I hear back from the head being taken off I'll post up the latest....
confusionhunter
Post by confusionhunter » Mon Feb 13, 2006 1:21 pm
You should also be able to find a second hand S3 engine cheaper than £3k I would imagine.... I would ring around all the 20VT tuners and see if they have one..... they normally have an eye on any engines kicking around. Try Pitstop developments, Jabbasport, dialynx and TSR etc etc
Mark.
DuncS3
Post by DuncS3 » Mon Feb 13, 2006 2:25 pm
Guy on tyresmoke had the same problem, he sourced a new engine as it was cheaper.
Try cupranet, tt-forum, tyresmoke to see if anyone knows of an engine
I would though get the engine built by Jabba to a better spec ;)
Dunc
BlackS3
Post by BlackS3 » Tue Feb 14, 2006 3:25 pm
3rd piston has melted at the back?? Due to running lean which in turn melted spark plug. Need a rebuild or new engine. I'll post up more details later.
sitas3
Post by sitas3 » Wed Feb 15, 2006 2:24 pm
Bad luck! really.. I wonder how many other S3/TT's have gone the same way? Also its got me thinking about whether this affects the BAM engine (que Dunc who is also has higher oil consumption??)..
sitas3
Post by sitas3 » Wed Feb 15, 2006 2:25 pm
also, did the dealer advise why the car was running lean? has it been remapped previously at all? dodgy MAF/induction leaks etc. It would be good to know their thoughts.
BlackS3
Post by BlackS3 » Fri Feb 17, 2006 9:20 pm
Totally standard car. If MAF goes dodgy car doesn't run well. Mine ran perfectly other than oil usage. Will have to rebuild engine to find out where fault is occurring. No fault codes or any indication of anything amiss. Will post photos over weekend. Maybe leak in gasket?? Who knows right now. I've spent 400quid already this month but realistically it's gonna cost £1000's to find out and fix. It's costing me 70quid a time to ferry it to and from garages but now it's going to be parked up for a bit while I start saving.
HTC
Post by HTC » Sun Feb 19, 2006 1:49 am
Darn, I feel really sorry for you.
I also think that a 2nd hand engine would be the cheapest and easiest route to take. Would be a quick swap too.
BlackS3
Post by BlackS3 » Mon Feb 20, 2006 2:46 pm
Here are some of the pictures taken of my car's engine following removal of the head. The first 3 clearly show damage to the No 3 piston and bore, including the melting of one side of the piston crown. The 4th shows all 4 pistons. Pictures of the valves are in my following post.
BlackS3
Post by BlackS3 » Mon Feb 20, 2006 3:03 pm
And here are a couple of pictures of the head showing the valves for No 3 cylinder and all the valves. Apart from some minor pitting between the 2 exhaust valves of the No 3 cylinder - and subject to the valve seats being repairable if damaged - the head will hopefully not need replacing. The 2 exhaust valves show signs of some pitting in the centre - more noticeable on the RH one in the photo. Unfortunately the No 3 spark plug is not available to photograph but, apart from showing signs of overheating, the only damage evident was that a very small piece of the centre ceramic insulator was missing.
DuncS3
Post by DuncS3 » Mon Feb 20, 2006 5:46 pm
Sorry to here that its terminal - please keep us informed of your progress
Dunc
Return to “S3 (Typ 8L) 1999-2003”
