Any ideas? No issues reported to me yesterday when I took it for its MOT.
is the original part and it was the shaft that got stuck and wouldn’t move
bill
Chinny wrote: ↑Thu Jan 25, 2024 8:17 pmSo part 2 of the car won’t start. Last Thursday morning was about to take my daughter to school and same thing happened again. Clutch down and nothing. Opened the door to see if I could hear anything and all I was getting was a click. Called the RAC who put a jump pack on and still only a loader click. The starter motor had given up. Car was booked in to have a forge oil cooler for the 12th of February and the garage [VRT]. Gave them a bell and they took it in early for me.
So new starter, new oil cooler , service. One of the Rear break callipers is sticking so that’s getting sorted. Leak from one of the power steering pipes. A New power steering cooler. Plus a few other jobs getting done while it’s there. And a largebill
I do something leave the car sat for a few days and it would start fine. I used to use it to and from work 5 days a week plus school drop off it wouldn’t normally get used over the weekend. On this occasion I used the car the day before and it was fine but the next day it wasn’t. I did get a price for the starter from Audi think it was £625 or £675. Then fitting on top. The car is with an Indy dealer. As it was going there for the oil cooler leak. I’m not in the country and the cars still with them so can’t give you a price of the starter plus fitting now but if you want I’ll let you know much that was.GhiniRS4 wrote:Chinny wrote: ↑Thu Jan 25, 2024 8:17 pmSo part 2 of the car won’t start. Last Thursday morning was about to take my daughter to school and same thing happened again. Clutch down and nothing. Opened the door to see if I could hear anything and all I was getting was a click. Called the RAC who put a jump pack on and still only a loader click. The starter motor had given up. Car was booked in to have a forge oil cooler for the 12th of February and the garage [VRT]. Gave them a bell and they took it in early for me.
I've been dealing with this issue for quite some time now. Can I ask, does the difficulty in starting only occur after the car has been sitting idle for a few days (around 4-5 days) and then you try to start it? I've been experiencing a similar problem for a while. If it fails to start initially, and after trying a few times (with no response, at most just a clicking sound from the starter motor), waiting for about 2-3 minutes seems to help, and then it starts. In the worst-case scenario, if it still doesn't start after the above process, I turn off the ignition, go back inside the house to get something, and then try starting it again (waiting for about 5-10 minutes), and it usually starts on the first try.
※ If used daily, there are no issues with starting. The problem only occurs after the vehicle has been idle for some time.
I'm really hesitant to address whether the starter motor needs to be replaced. Besides the part being expensive, replacing this component is somewhat difficult. Although there are online videos from fellow car enthusiasts demonstrating how to effectively replace the starter motor, whether the technician is willing to accept this method is another matter altogether.
So, I'd like to know if, after leaving the vehicle unused for an extended period, trying to start it again, the starting process has been normal?
Thank you.
Thank you for your response. Although I cannot provide a definitive solution to the problem yet, I hope that by sharing these experiences, we can identify the issue. When you return, I hope you won't mind sharing the subsequent usage status with us again. Also, thank you for your willingness to provide information. I have already contacted some parts suppliers to inquire about prices.Chinny wrote: ↑Mon Jan 29, 2024 6:38 pm
Hi bud. Sorry totally forgot to put up the cost. For the starter.GhiniRS4 wrote:Thank you for your response. Although I cannot provide a definitive solution to the problem yet, I hope that by sharing these experiences, we can identify the issue. When you return, I hope you won't mind sharing the subsequent usage status with us again. Also, thank you for your willingness to provide information. I have already contacted some parts suppliers to inquire about prices.Chinny wrote: ↑Mon Jan 29, 2024 6:38 pm
Best regards.
is the breakdown of costs
. Luckily I took a 3yr warranty out when I 1st owned the car in 2019 so it got changed under that.
Ignore my dreadful suggestion above! As it turns out this doesn't work all the time..... doh.OPOGTS wrote: ↑Fri Mar 15, 2024 11:45 amHi everyone, new to the the forum, just picked up my 'new' B7 RS4 Avant last month, loving it, will post about that separately at some point!
I have also had this sporadic starting issue and only the first start of the day. What I've learned so far is you have to press the button and then WAIT. Sometimes up to 5 seconds, and then the car will start. I'd obviously kept pressing the button, which must then turn it off or reset something, but if i do absolutely nothing it does actually start fine.
No idea why, but so far thats worked the last few times I've had the issue.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 40 guests
