Gearbox valve body problem
Frazz82
Post by Frazz82 » Fri Nov 17, 2023 3:10 pm
Just on with servicing the gearbox an I think this plastic bit and spring has come out from the valve body.
Anyone know where it goes before I put it back together.
Re: Gearbox valve body problem
Post by Shoppinit » Fri Nov 17, 2023 3:18 pm
Frazz82
Post by Frazz82 » Fri Nov 17, 2023 3:35 pm
Not in any of those mate.
Post by Shoppinit » Fri Nov 17, 2023 4:01 pm
Have a look through the repair manual to see if you can spot it:
https://procarmanuals.com/pdf-online-zf ... ir-manual/
Is it part number 748 here?
Frazz82
Post by Frazz82 » Fri Nov 17, 2023 4:03 pm
This is the part. Need to see where it goes now.
Frazz82
Post by Frazz82 » Fri Nov 17, 2023 4:24 pm
Think it maybe here
Frazz82
Post by Frazz82 » Fri Nov 17, 2023 7:48 pm
Found where it went so all back together. New filter, harness and a clean out.
Still getting 18223 and 18243 fault codes but only if u lewve ignition on a second if u turn key and start straight away there is no fault codes.
Going to the f125 switch next.
Users browsing this forum: B_O_N_K and 107 guests
