RS6 steering wheel badge insert
Re: RS6 steering wheel badge insert
You might have to remove the centre spigot iirc.
Cool. These are rare.
Yes they are now very rare.
Might get one for a spare.
Even though I have 4 ( or 3 ) somewhere and cannot find them.
The VCDS cable eventually turned up.
So hopefully the badges Will miraculously appear and show themselves.
Do it.
Ha ha. Shopp.
As I said previously. I need to reduce the expenditure on the car at the moment.
Did I really say that !
Yeah, but that's only 0.08 of one standard RS6 currency unit.
CAUTION
I tried to contact the seller to find out if these would fit a rs6 c5 steering wheel.
Unable to contact the seller and I have tried many times.
Then read the negative feedback comments.
So I would proceed at your own risk.
Thought this was a nice alternative. I kind of prefer it as the writing is larger and stands out.
I have ordered two badges to see how they fit.
At just over £4.70 each we’ll worth a punt.
Tried to order 4 but it would only allow a maximum of 2.
Seems to be showing as out of stock now, so maybe you simply got the last 2?steve2003rs6 wrote: Tried to order 4 but it would only allow a maximum of 2.
You'll soon control the steering wheel badge market!
Hi Nick. Problem is they disappear for no apparent reason.
So I have to allow for “spring cleaning”
Surprised that the poosey pipes are still where I put them.
I now try to keep my parts in the car ?
Now to see how they fit.
As a consequence they sit further down inside the steering wheel.
Could be a good thing as they are less likely to wear from rubbing.
You could always use some double-sided adhesive foam to mount if you wanted it flush.
That’s a good idea Ben
Just wanted to see if they were any good as a alternative.
As the original type are so hard to get hold of.
I will remove this one and put my other one back in.
