Afterrun fans
steve2003rs6
Re: Afterrun fans
Post by steve2003rs6 » Wed Jun 14, 2023 9:56 am
Ran diagnostics.
Error code 18080 p1672 004.
Could not start fan via Vagcom.
On a positive note. When I moved the car this morning there was no oil patch.
Hope it continues.
Re: Afterrun fans
Post by Shoppinit » Wed Jun 14, 2023 11:09 am
Got to go back and check the fuse. The power to the fuse, then continuity from fuse to fan.
Then check the pwm signal at the fan. If no signal, trace back to ECU.
What is the text of the error code?
steve2003rs6
Re: Afterrun fans
Post by steve2003rs6 » Wed Jun 14, 2023 1:56 pm
Hi Ben.
The message was Open or short to ground.
Hope we can get it sorted as the oil temp was at 90-95 on the gauge on short distances.
Before the oil temp would sit at 85 ish all day long.
Re: Afterrun fans
Post by Shoppinit » Thu Jun 15, 2023 2:45 pm
Have you checked the 2 big fuses (19 for fan 1 and 22 for fan 2):
steve2003rs6
Re: Afterrun fans
Post by steve2003rs6 » Thu Jun 15, 2023 5:14 pm
Hi Ben. Car has been in garage all day today. So far not heard anything.
The above fuses. Are they located in engine compartment or in the cabin.
Thanks mate.
steve2003rs6
Re: Afterrun fans
Post by steve2003rs6 » Thu Jun 15, 2023 5:26 pm
Success. Problem solved. Bad connection at the plug and socket.
Pick the car up in half hour.
Well that was a marathon amount of work.
steve2003rs6
Re: Afterrun fans
Post by steve2003rs6 » Thu Jun 15, 2023 5:57 pm
By the way the oil leak was finally cured.
It was the Turbo oil drain pipe.
The face was stretched and out of true.
Face dressed up with a file so that it was flat, and new gasket and o ring installed.
No oil patches in 3 days. Wife very happy.
Re: Afterrun fans
Post by Shoppinit » Thu Jun 15, 2023 6:08 pm
Great News. I thought the fan would be something silly.
steve2003rs6
Re: Afterrun fans
Post by steve2003rs6 » Thu Jun 15, 2023 6:11 pm
Pleased it was.
But the old fan is still faulty.
Drive home was really quiet ?
Ps the hydraulic engine mount that showed faulty has miraculously cured itself.
Christine at it again.
steve2003rs6
Re: Afterrun fans
Post by steve2003rs6 » Fri Jun 16, 2023 11:49 am
Happy wife. No oil drips on the drive.
It definitely was the turbo oil drain pipe.
This was the third attempt to cure the leak from this pipe.
Gasket and o ring replaced every time.
This time making the surfaces flat appears to be what was needed to finally cure the leak.
steve2003rs6
Re: Afterrun fans
Post by steve2003rs6 » Sat Jun 17, 2023 8:23 pm
Deep joy. Been out in the car all day. Oil temperature has been spot on. I don’t think it went above 85 degrees c even in todays hot weather.
steve2003rs6
Re: Afterrun fans
Post by steve2003rs6 » Mon Jun 19, 2023 12:03 pm
FFS. Oil leak back again.
Back in garage Wednesday 08:30
steve2003rs6
Re: Afterrun fans
Post by steve2003rs6 » Mon Jun 19, 2023 12:16 pm
At least we have got rid of the cooling fan error.
steve2003rs6
Re: Afterrun fans
Post by steve2003rs6 » Mon Jun 19, 2023 7:20 pm
Does anyone know the part number for the near side turbo oil drain pipe.
Felix2566
Re: Afterrun fans
Post by Felix2566 » Mon Jun 19, 2023 8:56 pm
right lower oil return line 077145736C
seal for turbo end of the line 058145757C
o ring for sump end of line N90981601
Users browsing this forum: asgor, Cunningstunt and 74 guests
