Screen Wash reservoir leak
RS4786
Post by RS4786 » Thu Jun 15, 2023 7:48 am
Hi guys as title will i have to remove bumper to repair leak from the screen wash res ? Can see drips from around the foglight area thanks
delroyx
Re: Screen Wash reservoir leak
Post by delroyx » Thu Jun 15, 2023 12:20 pm
I think there is a pump which can leak which can be accessed through the wheel arch.
Pretty sure the resevoirs come in two parts
delroyx
Post by delroyx » Thu Jun 15, 2023 12:23 pm
Are you sure it's not the aux rad or condensation from the air con. Guessing you've checked the obvious...screen wash level!?
RS4786
Post by RS4786 » Thu Jun 15, 2023 1:06 pm
Leak is def from the washer res as can see it coming straight out when you top up plus warning light on dash
Will i just need to replace a seal o ring as pumps are working just dont hold fluid.
Spwong
Post by Spwong » Mon Jun 19, 2023 5:55 pm
I replaced a bunch of grommets around the washer reservoir, from my notes: "Replaced windshield pump grommet, sensor grommet, 2nd overflow tube grommet. Replaced several wheel arch liner fasteners and nuts. No leaks! Headlight pump grommet about the only one not changed". All were accessed by removing the wheel arch liner.
Users browsing this forum: No registered users and 325 guests
