Hi guys
It’s been a long time since I done any meaningful work to the RS, only managing to snatch an hour here and there.
I’m pleased to say that I’ve now got everything I want off the car. I’ve still yet to brake some of those parts down, namely the rear drive shaft and hub, but hopefully that should be straight forward enough.
What I would like some help with is part numbers and alternatives where needed.
I’ve already got a full rear end polly bush kit and lower control arm eccentric bolts.
Here’s the parts list with links to AD.
Rear drive shaft rebuild
https://audi.7zap.com/en/rdw/audi+rs6+r ... 501010/#13
2x 4D0598103 https://m.autodoc.co.uk/gsp/145382
2x 8E0598099A https://m.autodoc.co.uk/nty/16550656
Hub
https://audi.7zap.com/en/rdw/audi+rs6+r ... 505030/#16
2x 4D0407625E https://m.autodoc.co.uk/skf/1362297
Brake cable
https://audi.7zap.com/en/rdw/audi+rs6+r ... -609080/#6
1x 4B0609765C (will need help acquiring this part)
1x 4B0609766C (will need help acquiring this part)
Speed sensors (been chatting to Matt about these and I’m going to take a punt on the following)
1x https://m.autodoc.co.uk/meyle/8869182
1x https://m.autodoc.co.uk/meyle/8869202
If you think there may be other parts please do let me know.
Parts for the rear end rebuild?
Re: Parts for the rear end rebuild?
re ABS sensors - my bet (hope) is that it's a compatible sensor, but just the plug/wire/bung etc that's different.
I’ve ordered a pair of each. If there’s no issues fitting them
How did you get on with the eBay headlight levelling sensors? Or am I imagining this?
I managed to make the front fit. Not looked at the rear yet though.
Users browsing this forum: Bing [Bot] and 93 guests
