Violent judder!!
4.2 V8 32v FSI - 444 bhp
Rs4nutter
Violent judder!!
Post by Rs4nutter » Sat Aug 27, 2022 2:38 am
Morning all
Used car for first time in a while, started juddering on way to work. It was like it was about to cut out, and had a hesitation at one point and did nothing, few seconds later then decided to go.
Started the car next morning to an erratic idle, between 1000 - 2500rpm before settling down, while this was happening I had the max rpm warning light come on, then the EPC light on!!
Just managed to get it home but it got worse, at one point it juddered that bad I nearly head butted the steering wheel!!
Have had it looked at by CM Tuning but couldn’t get the car to do this, but did reset the gearbox adaptions, worked for a while, but now it’s back!!
Any ideas would be grateful
TheBigFish
Re: Violent judder!!
Post by TheBigFish » Fri Jan 27, 2023 11:46 am
Hi! Did you find out what the problem was?
Rs4nutter
Post by Rs4nutter » Sat Jan 28, 2023 2:52 am
Hi TheBigFish
Took to a garage up road near me, non Audi/speacialist and they plug computer in and it had a fault light on dash, was put down to a fuel pressure sensor on bank A.
Changed that and so far not had the same problem back 🤞
Hope that helped?
TheBigFish
Post by TheBigFish » Thu Mar 23, 2023 11:45 am
Great thanks for the reply!
I always find with cars that a lot problems seem to be common faults. I had this high rpm warning too so will change the low presssure sensor too :-)
Cheers,
Ben
Users browsing this forum: Google Adsense [Bot] and 16 guests
