Coolant
Coolant
Not sure if I have a (slow / undetected leak), but has anyone else experienced coolant levels dropping over time?
I had an interim service at 4 rings in October, and just checked coolant while topping up washer fluid and the float was low.
Mixed 1:1 VAG coolant with distilled water and it took about a litre to get the float to pop all the way up again. I'll keep monitoring of course but seems fishy.
2018 B9 RS4 Daytona Grey
Re: Coolant
This came up some time (couple of years!) ago my car used a little coolant in the first few months but has since settled down.
Re: Coolant
Good to know, thanks. This is around 40k miles though so would hope everything is fully bedded in now!
Rusty Racer
Re: Coolant
What's your oil like?
2022 RS4 - Turbo Blue / Black
Gone: 2018 RS4 - Navarra Blue / Black, 2016 A6 BiTDI - Midnight Blue / Black, 2016 Golf GTD with a "lot" of toys, 2016 M3 CP - Mineral Grey / Black, 2009 135i - Le Mans Blue / Black
Re: Coolant
I haven't had any oil related issues. Everything looks clean around the cap. No comments on fluids at all at the last interval, except that it's due a sport diff oil change so I'll get that done and enquire about coolant on the same trip I guess.
Re: Coolant
So hopefully your coolant isn't mixing with the oil then...
Re: Coolant
While diagnosing another fault I noticed that I had lost about 350ml of coolant. Roughly 200ml below Min.
There are no visible external leaks to be seen any where.
I decided to check the intake system after seeing a YouTube video on an RS with a leaky charge cooler and voila! I have a small weap of coolant into the charge cooler that I found by removing the return air pipe from the charge cooler to the throttle body and looking at the side and bottom of the heat exchanger element. There is a small weap of water from the elemet and a pool of coolant at the bottom of the charge cooler. There are also signs of small amounts of coolant on the inside of the charge pipe and throttle body butterfly.
It looks like I've caught it early and will be replacing it ££££
Rusty Racer
Re: Coolant
Have you got a link to that YouTube video? Definitely something I want to check too!Jools wrote: ↑Tue Apr 11, 2023 8:31 amWhile diagnosing another fault I noticed that I had lost about 350ml of coolant. Roughly 200ml below Min.
Re: Coolant
Check out Vag Technic on YouTube. They are dealing with all sorts of RS wowes
I've attached a few pic's inside my intake system, one shows a drop of liquid on the butterfly of the throttle body. Then a splt screen of the side of the charge cooler core with liquid running down it (LHS) and you can just make out the reflection of a small puddle at the bottom of the charge cooler case on the RHS. I also found some on the sides of the two delivery pipes into the inlet manifolds.
I'm looking to see if the water matrix can be replaced as a new OEM unit is £1200, an uprated after market one is £2000 and a full after market charge cooler & its radiator is £3000 (Stage3)
I figure if I can refactor it for maybe £400 it could be forth running a part exchange scheme.
Apparently the main problem is getting the air side to seal correctly after you have had it apart as it's running at upto 2 bar depending on your tune if you have one.
Re: Coolant
Bear in mind the channel called "VAG Technic Car Abuse" https://www.youtube.com/@vagtechniccarabuse4837
The TLDR is that VAG Technic might not be a reliable source.
Gone : 2017 M3 CP
Gone : 2007 B7 RS4 (
Gone : 2017 M3 CP
Re: Coolant
I am aware of the complaint against the guys at Vag Technical and I do not condone there actions or driving.
Did that chap ever post an indepentant engineers report on his engine failure, it would make interesting reading?
I am not promoting or commenting on there work but was merely pointing out they are one of the few channels to post the problems they have come across with specifically the RS V8 and V6 engines, I'm sure Audi won't be posting any teardowns any time soon. Most of the videos out there are on how to make your RS go faster, not on how to mechanically fix it.
Do you chance your arm with an Audi specialist non-dealer garage or let your local the Audi dealership 'service center' super tech at £200/hr suck through his teeth and say 'you need a new engine mate' and he might have been on a course on how to do an engine swap 18 months ago!
I'm sure RE Performance would be a good bet, but probably more expensive than Audi, but then It would be better built than by Audi!
It's all horse for courses, if we will insist on driving complicated expensive performance cars and gripe at dealer prices when it goes horribly wrong someone will always be there to step in to fill the gap and make a buck along the way.
The world ain't always shinny!
