DRC coding out with VAG com etc???
5.0 V10 50v biturbo - 571 bhp
Doug_RS6
Post by Doug_RS6 » Tue Jul 06, 2021 8:07 am
I'm considering coilovers for my C6 RS6. the DRC just doesn't have a nice setting. Comfort it too soft and dynamic too hard. Plus I like the ability to set the ride height exactly where I want it.
Can anyone confirm or deny that The whole DRC system including the menu in the MMI can be turned off with Audi software?
BobBobson
Re: DRC coding out with VAG com etc???
Post by BobBobson » Tue Jul 06, 2021 2:18 pm
I had to use VAG-COM, I think you can turn off the damping selector in the MMI via the ‘hidden menu’ but that would still leave the suspension warning light on the dash.
Doug_RS6
Post by Doug_RS6 » Sun Jul 11, 2021 8:30 am
You can't make the car believe it isn't fitted then?
BobBobson
Post by BobBobson » Sun Jul 11, 2021 11:00 am
Sorry, I read the question as ‘without vag-com etc’…
Using vag-com you can completely code out the DRC and the variable damping, so no MMI menu and no light on the dash.
I have removed the controller entirely from the car and it’s quite happy
Doug_RS6
Post by Doug_RS6 » Sun Jul 11, 2021 12:14 pm
Excellent. Was it fairly simple or does it involve anything complicated? I've not used Vag Com before but have used BMWs equivalent etc.
BobBobson
Post by BobBobson » Mon Jul 12, 2021 1:02 pm
It’s far easier than ediabas or inpa!
From memory I don’t think too much coding was involved, you definitely have to remove the control unit from the list of installed modules in the can-gateway:
https://youtu.be/yHNUUAK6GNs
I have some notes around coding changes but it doesn’t look like I had to do any. Once the module is coded out of the gateway you can either remove the module (behind the glovebox) or pull the fuses as otherwise it’ll generate a (harmless) error code about being unregistered.
Doug_RS6
Post by Doug_RS6 » Tue Jul 13, 2021 5:13 pm
Excellent thanks. This may make my move to coilovers much easier.
Imola_Sid
Post by Imola_Sid » Thu Feb 09, 2023 4:01 pm
Anyone have more information on how exactly to code out the DRC and which fuse needs pulling?
Imola_Sid
Post by Imola_Sid » Sat Feb 11, 2023 9:31 pm
For future reference, coded the DRC out (unchecked the elec suspension options using Vagcom) and removed 2 fuses on the passenger's side near the door. No lights on the dash 😀
French
Post by French » Thu Nov 16, 2023 2:06 pm
If you buy KW's there is an option to add DRC defeat electronic box....
harm
Post by harm » Mon Mar 04, 2024 11:51 am
Can you tell me what coding removes the drc and which specific fuses need to be removed?
Imola_Sid
Post by Imola_Sid » Tue Mar 05, 2024 6:07 pm
I unchecked the elec suspension and the fuses are numbered on passengers side
harm
Post by harm » Wed Mar 06, 2024 4:35 pm
ok thanks
Users browsing this forum: CupraDine and 57 guests
