FIS Control
Mɐʇʇ
FIS Control
Post by Mɐʇʇ » Fri Oct 25, 2019 9:15 am
Has anyone installed FIS control (fis-control.de)?
I quite fancy the snake game
Jayjay101
Re: FIS Control
Post by Jayjay101 » Fri Oct 25, 2019 9:17 am
I’ve thought about it, but u can get a p3 gauge that go’s in the air vent and I think that’s go more on it I could be wrong.
Mɐʇʇ
Re: FIS Control
Post by Mɐʇʇ » Fri Oct 25, 2019 9:45 am
I hear you, and some of them do look smart. However, I honestly don't think there's a day to day need (for me, at least) for all the detail you can get out of these. Sometimes boost is useful as an early heads up if something is in distress - but the rest of it I would immediately want logged via VCDS anyway.
However, snake FTW.
Ajc
Re: FIS Control
Post by Ajc » Fri Oct 25, 2019 10:29 am
I'm half way through building a raspberry pi with a 4 inch touch screen too fit into an air vent , that when I figure it all out should display what I need and more , also little touches like being able too have programmed buttons on the display for ic fans , exhaust cut outs . Oh and I take your snake and raise it too pacman built in
Cheers Al
Jayjay101
Re: FIS Control
Post by Jayjay101 » Fri Oct 25, 2019 10:46 am
Ajc wrote:I'm half way through building a raspberry pi with a 4 inch touch screen too fit into an air vent , that when I figure it all out should display what I need and more , also little touches like being able too have programmed buttons on the display for ic fans , exhaust cut outs . Oh and I take your snake and raise it too pacman built in
I’m in for Pac-Man!!
Mɐʇʇ
Re: FIS Control
Post by Mɐʇʇ » Fri Oct 25, 2019 10:52 am
You win. Pac-man>Snake. :D
mikep99
Re: FIS Control
Post by mikep99 » Fri Oct 25, 2019 10:56 am
Interesting...
I've also got a little project going on for my RS4.
Using an arduino/ESP to get values wirelessly via the obd port and show them on the top 2 lines of the dis where the music info. normally is.
A few little tweaks with it and I'll be happy.
Mike
Sent from my PRA-LX1 using Tapatalk
Ajc
Re: FIS Control
Post by Ajc » Fri Oct 25, 2019 12:04 pm
Interesting...
Mike
I have a couple of arduinos which I may end up using for the inputs from the harness for the sensors then over too the pi . I've not done much on mine for a while but need to pick the project up again at some point .
Matt , I do like the dis upgrade , that was what kicked the while project off for me i think . They seem to be a fairly easy install to . As you say just for a boost reference at a glance its ideal for the job .
Cheers Al
Mɐʇʇ
Re: FIS Control
Post by Mɐʇʇ » Fri Oct 25, 2019 12:12 pm
Does anyone know the difference between FIS full and FIS light? Light is cheaper, but can't find anything that explains the difference.
Re: FIS Control
Post by Shoppinit » Fri Oct 25, 2019 2:54 pm
If he’d released it 10 years ago he would have made a killing.
mikep99
Re: FIS Control
Post by mikep99 » Sat Oct 26, 2019 9:56 am
MattV8 wrote:Does anyone know the difference between FIS full and FIS light? Light is cheaper, but can't find anything that explains the difference.
From what I can tell, it looks like FIS full can have additional external sensors plugged into it and shown on the display.
Not sure if there's any other differences.
Mike
Puggie
Re: FIS Control
Post by Puggie » Sat Oct 26, 2019 9:27 pm
For anyone doing arduino style hacking, look at the 'teensy' boards, they do a neat one (v3.2 I think) with dual can channels on it. This is very useful for taking one can stream in altering it and spitting out another modified network to a device. Signal to your dash in, then remove the CAN error messages and send that data out on the other can network to your dash (no MOT concerning warning lights)
It's a neater solution than an arduino and CAN shield IMHO.
Sent from my F8331 using Tapatalk
anditsoundslikebells
Re: FIS Control
Post by anditsoundslikebells » Sat Jan 28, 2023 8:28 pm
Maybe there is a better thread to bring back?
I'm thinking to install the FIS control unit.
All I'm really after is boost info and the current gear (at all times, including auto/sport mode)
I like the face the OEM display is used. There are some fancy colour displays but I think that detracts from the OEM look.
Does anyone know if it's feasible to somehow get the FIS display to just show the current gear? In a large format? Like the whole display?
https://m.youtube.com/watch?v=fTmMoa-X-zA
https://m.youtube.com/watch?v=YkxdWZVaYpg
https://www.drive2.ru/o/b/2998051/
I think this looks great:
RS6 C5 Avant 2002 Daytona Grey
TTH 620 - Wagner IC - OC.T 200cell&downpipes - DW400 pump - 034 TCU chip - FIS - B16 PSS9 - 034 control arms - H&R ARB - OZ Superturismo
itreallyisRob
Re: FIS Control
Post by itreallyisRob » Thu Feb 02, 2023 5:42 pm
This is exactly what I've been after! My dis is going pixalated now anyway so was going to replace but this seems much better!
Have you managed to find anymore information that's in english?
Mɐʇʇ
Re: FIS Control
Post by Mɐʇʇ » Thu Feb 02, 2023 6:01 pm
Hmm. If there were a group buy of FIS Control, I could maybe be tempted, so I can sneak out to the garage and play snake in the car sometimes for a bit of peace and quiet.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 132 guests
