Drive train shunt
ChrisH2017
Re: Drive train shunt
Ok will have a look. One thing I have noticed occasionally recently is when getting out of the car after a drive a quite strong petrol smell from the drivers side, near the filler cap, but maybe from underside somewhere. Didn't think it was related, but maybe..?
Could be. You shouldn’t be smelling petrol.
Astrosquirrel
Could it even be the fuel filter?
Could be. If it’s never been changed. I would think the problem would appear more consistently if it was due to poor flow though.
ChrisH2017
Yes, I would be surprised if it was a fuel issue as it still goes like a stabbed rat, even when it's jolting, the jolts seem slightly worse when on throttle but not massively so. If it was fuel releated i would expect it to be much worse when on throttle. I will do checks around the pump and filter to see if there is a problem, would be good to get any leak fixed anyway. I am lean towards some.other driveline issue, maybe a cv joint or diff? It's very odd.
Check around the fuel pressure regulator. That’s a potential point of failure.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 92 guests
