Door open red warning lights on door
steve2003rs6
Post by steve2003rs6 » Fri Jan 13, 2023 2:47 pm
Noticed front passenger door red light wasn’t working when door open.
So I replaced the door bulb.
Now none of the door lights work
And the dashboard shows all doors ajar.
Any ideas ?
Also now when I lock the car a short time later the car alarm is triggered.
Re: Door open red warning lights on door
Post by Shoppinit » Fri Jan 13, 2023 3:06 pm
Check for water under the carpet around the CCM. Maybe the fuses. Can you connect to the CCM with the Vagcom? Module 35 from memory, but could be wrong.
Post by Shoppinit » Fri Jan 13, 2023 3:07 pm
What bulb did you replace with? Regular or China special LED?
steve2003rs6
Post by steve2003rs6 » Fri Jan 13, 2023 3:11 pm
Regular.
I reckon a fuse but don’t know which one.
Post by Shoppinit » Fri Jan 13, 2023 3:14 pm
I'll have a look.
steve2003rs6
Post by steve2003rs6 » Fri Jan 13, 2023 3:23 pm
Thank you Ben.
srichards
Post by srichards » Fri Jan 13, 2023 3:24 pm
This looks similar to what is in the owner manual.
https://www.autogenius.info/audi-rs6-c5 ... x-diagram/
steve2003rs6
Post by steve2003rs6 » Fri Jan 13, 2023 3:42 pm
Also none of the interior lights are working.
Everything was working until I changed the passenger door light bulb.
steve2003rs6
Post by steve2003rs6 » Fri Jan 13, 2023 3:54 pm
Ok replaced fuse 14. Interior lights back working.
All doors open showing on dash now back to normal.
I switched the 10A fuse no 14 with the fuse below it which is also 10A. Thanks for diagram suz.
Battery indicator warning now showing on dash.
I will nip out and get a new fuse to replace that one.
Thanks for the help guys.
Post by Shoppinit » Fri Jan 13, 2023 4:18 pm
Cool. Saved me the trouble of firing up Elsa.
Users browsing this forum: Google [Bot] and 101 guests
