Hi All,
My windscreen de-mister blower fans have stopped working today even though they were working fine earlier on today when i first got in the car.
All blower control buttons on Centre console are illuminated and work.
But when you put the fan on with the buttons the fan isn't coming on / kicking in at all.
Any ideas on what this could be ? I've checked the fuses they all seem to be ok!
Has anyone experienced this issue before ?
Any advice will be greatly appreciated ?
James
WINDSCREEN DE-MISTER BLOWER FANS NOT WORKING
RS6C5AVANT81
Re: WINDSCREEN DE-MISTER BLOWER FANS NOT WORKING
Most likely is the fan. Have you checked to see if you're getting voltage to it?
Mine did the same earlier this week, I popped off the cabin filter and gave fan a quick flick and all ok.
Resister is easy enough to change but not sure if when that fails it gives a constant rather than variable speed. Remove the glove box and you will see it on the ducting.
Daytona RS6 Avant
RS6C5AVANT81
To update everyone .....i replaced the heater blower fan motor resistor - problem fixed ! £25 Well spent ! CHEAP FIX!
Can I ask were you bought the motor resister as my car has same issue thanks
Users browsing this forum: No registered users and 108 guests
