Winter Wheel Sizes
Winter Wheel Sizes
I know that the smallest oem wheels were 19 inch but I've got a set on 18x8.5 JJ ET32 alloys with winters on that I only used for 4 months last year on my old B8.5 S4 does anyone know if there's the clearance on the discs/calipers to put these on my B9 RS4? Or is it simply a case of, jack it up and see.
Re: Winter Wheel Sizes
You might find the clearance on the calipers a bit tight on 18"
The OEM 8 x 19 et 26 on 325 40 19 tyres
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Check the edge of the drivers door. It will give you the tyre sizes for Mud & Snow (M+S). This will give you the your wheel size.
If it says 19" then theres probably a reason why they didn't put and 18" option on there.
I have attached a pic of my B9 label
I hope this helps
Jools
I hope this helps
Jools
