Zimmerman Discs.. update - help needed re pad sensors
Re: Anyone used Zimmerman discs on their C6 RS6?
The rear OEM pads come with a sensor built in from the ETKA drawing, not actually fitted them myself so have no idea if thats an accurate drawing or not.
Imola_Sid
Ian and Jim - thank you.
I've ordered a full set of Zimmermans and DS2500 pads all round
Rear pads are sensor-less
Imola_Sid
Update...
Had the discs and pads fitted on the weekend (Zimmerman discs with DS2500 pads). I fitted new brake pad sensors and the light wouldn't go on the dash. I tried cutting the plug and joining the wires together but still no luck
Any ideas?
Any ideas?
Imola_Sid
Re: Zimmerman Discs.. update - help needed re pad sensors
I'm not sure to be honest...
There aren't any faults or anything showing when checking with Vagcom.
If anyone knows if it needs resetting/how to do it, please share
Jim Haseltine
It's not a stored code or anything like that, it's simple - as long as the pad circuits are complete the light stays out. I think it was Ian who had a problem with a break somewhere else in the loom that caused the light to stay on.
Imola_Sid
Ah! Sounds like it's going to be a pain to find out where the break is
Jim Haseltine
Worst case, track the wires back to the engine firewall bulkhead and try shorting them together there, if it works then you know that the broken wire is in the wing wiring somewhere rather than in the cabin wiring between the ECU and bulkhead.
Imola_Sid
Turned out that the previous owner had joined the wires in the loom and it had obviously gone bad over time. Sorted it out and no more warning lights. Brakes done
New Oil Level Sensor done
Next.. Starter motor and lowering springs.
Nice, an easy win, rare on these cars
Users browsing this forum: hartley1967 and 90 guests
