Astro's RS Needs TLC
Astrosquirrel
Re: Astro's RS Needs TLC
Post by Astrosquirrel » Sat Nov 26, 2022 1:53 pm
Shoppinit wrote:I think I remember seeing some on Autodoc.
They do throw a check engine light, annoyingly. You could keep the old one plugged in - presumably it wasn't giving errors.
Ah that's not the news I needed Image. I've rewelded the sensor as it was. The car was for sure not throwing engine check light on before I started working on it.
... Pretty sure the sensor was also just hanging there. I did remove the ac compressor and the PS steering pump, but I don't remember even getting close to that area.
When I changed the CPS I did rummage around the mount but the sensor was already hanging off the cable.
Fingers crossed I guess. It'd be a waste of work and fluids to have to remove the lock carrier once again.
Sent from my 2107113SG using Tapatalk
Post by Shoppinit » Sat Nov 26, 2022 3:35 pm
Yeah, but it was connected so no CEL.
Astrosquirrel
Post by Astrosquirrel » Sun Nov 27, 2022 10:46 am
Yep assuming the same an going YOLO.Image
On another note, checking my assumptions. These driveshaft bolts are stretch bolts and not reusable
However these M10s that attach to the flange on the gearbox are reusable (add locktite)
- Wrong, they also need replacing
Cheers.
Astrosquirrel
Post by Astrosquirrel » Sun Nov 27, 2022 2:48 pm
Got my answer from Bentley's. Both groups are to be replaced.
Astrosquirrel
Post by Astrosquirrel » Wed Nov 30, 2022 5:45 pm
Got all screws brand new.
Looking at auto-doc I get about 4 different Bosch oil filter, ranging from 6 all the way to 65 european shillings (m539 :)). Confused. Any experience or advise would be highly appreciated.
BTW More items to add to the EoL List:
- 078115561K oil filter
- 4A0121140 radiator plug :evil: :cry:
Post by Shoppinit » Wed Nov 30, 2022 7:30 pm
I'd get a Mann or OE filter.
Autodoc is being a bit crap there. The RS6 uses a cartridge filter like the first 3.
Why don't you cross-reference the OE part number?
Astrosquirrel
Post by Astrosquirrel » Wed Nov 30, 2022 10:07 pm
I'll go for the Mann filter then. My biggest problem at the moment is the radiator plug. It's not available anywhere. I'm hoping I can reuse the radiator from the donor car.
Post by Shoppinit » Wed Nov 30, 2022 10:50 pm
Looks like it would be easy enough to machine a new one if it came to it.
Users browsing this forum: Cunningstunt, Google [Bot] and 80 guests
