Car wax
Steve2003rs6
Car wax
I have used meguiars Canuba hard wax for years.
However getting rid of the white residue has been a pain.
So decided to give this a go.
Car all washed and clay bar.
Now to try the wax. I need to find a easier way to waxing after the operation I had back in June.
Re: Car wax
I use demon shine in the snow foamer after I wash the car. Semi-rinse it off, dry with a towel and the effect is the same as wax as far as I can tell.
Steve2003rs6
Re: Car wax
Cheers for that Shop.
Will keep it in mind.
Just finished waxing. It’s the buffing off that I am having difficulty with.
Re: Car wax
Would a car polisher/buffer help ? Not to try and get swirls out and burn through paint, just to lightly remove the white crust ? I've had one for a couple of years now but am scared shitless about making a large burnt patch or something
Steve2003rs6
Re: Car wax
Hi mark. I would be the same with a buffer.
I think I am going to have to do waxing in stages.
Bonnet ,roof, and boot
Have a rest
Offside wing, doors, and rear panel
Have a rest
As above to the near side
Have a rest
Then Finnish with front and rear bumpers.
Alternatively washed weekly and use a mobile detailer once a month.
Have a rest
Have a rest
Have a rest
Re: Car wax
The biggest mistake most people make when buffing is not using the right towel and often it can take 3-4 towels as the fibres become clogged with the excess wax when removed.
You may also want to try a different wax as there is a lot of variation between the compounds and how easily they’re removed.
Re: Car wax
I'd pay a good detailer to clean it properly and coat it with one of those good ceramic coatings. Then the maintenance becomes far less effort.
I'm hopeless at buffing so I now use the light spray on waxes that shine up really easily. I used to use autoglym and would spend the next weeks seeing white bits all over the place and having to keep removing them.
Re: Car wax
Steve, try this at least once:
http://www.carplan-international.com/de ... emon-shine
I replaced the Stvarnagloss with it when it became obsolete.
You don't need a snow foamer. You can get spray on versions. And also get some good quality microfibre towels.
I cover the car in it, including the glass and wheels. The effect is indistinguishable from a wax, except you don't have all your black bits go white like you do with wax.
Steve2003rs6
Re: Car wax
Cheers for the recommendations.
Appreciate all the advice.
Steve2003rs6
Re: Car wax
Update.
Goes on easy
No white residue
Very good beading in the rain. Hardly stopped raining since I put it on.
All in all pretty good wax. But it’s not cheap.
Goes on easy
No white residue
Users browsing this forum: No registered users and 286 guests
