On my quest to tidy up the underside of the car I came across, what was kindly identified by Shop, the DCR coupling (25) that was attached to a bracket I want to get powder coated (13/14). Coupling 25 is rather rusty so it’s my intention to remove that coupling and line (10&11) back to the next coupling (26), as I imagine it would be impossible to replace 25 without cutting lines 10&11 up anyway.
https://audi.7zap.com/en/rdw/audi+rs6+r ... 16-616030/
So my question is does this sound sensible/achievable and where would I find coupling no 26 or would replacing 25 be a better solution? I don’t really want to leave 25 in place as I’m not sure what the consequences of 25 failing could be (and it looks awful).
DCR pipework
Re: DCR pipework
The system could well still be under pressure. Those couplings contain valves that allow you to remove a shock without depressurising the system.
If I wanted to replace just that valve, then I would start by making a visit to some places that specialise in hydraulics. Like flexible hoses for mini-diggers and the like. Or contact a company like this to see if they can recognise it:
https://www.htsspares.com/catalogue/hos ... -couplings
I believe KYB manufactures the DRC system.
Re: DCR pipework
Or depressurise (extremely carefully, of course), cut the pipe, cap it and worry about it the day you decide to put the DRC back on.
Re: DCR pipework
Great, thanks.
Re: DCR pipework
Shoppinit wrote:The system could well still be under pressure. Those couplings contain valves that allow you to remove a shock without depressurising the system.
Sent from my 2107113SG using Tapatalk
Users browsing this forum: srichards and 153 guests
