Astro's RS Needs TLC
srichards
Re: Astro's RS Needs TLC
Post by srichards » Sun Nov 06, 2022 11:01 am
Doobry for the SAI maybe?
Post by Shoppinit » Sun Nov 06, 2022 11:16 am
If I had to guess, I'd say it was off the engine mount. What colour are the wires going to it?
Astrosquirrel
Post by Astrosquirrel » Sun Nov 06, 2022 11:49 am
Shoppinit wrote:If I had to guess, I'd say it was off the engine mount. What colour are the wires going to it?
As usual Ben, you're spot on. Thanks!
Sent from my 2107113SG using Tapatalk
Post by Shoppinit » Sun Nov 06, 2022 11:50 am
Cool. Suspect you'll need a new engine mount then. :)
Astrosquirrel
Post by Astrosquirrel » Sun Nov 06, 2022 11:57 am
Shoppinit wrote:Cool. Suspect you'll need a new engine mount then. :)
Great... List keeps growing Image
Astrosquirrel
Post by Astrosquirrel » Sun Nov 06, 2022 1:28 pm
Aw come ooooon that's just mean Image
Sounds like someone knocked it off and then decided the best course of action was to just stick it back on Image
steve2003rs6
Post by steve2003rs6 » Sun Nov 06, 2022 2:57 pm
Had a few jobs done locally and they have broken stuff and not told me.
That really winds me up.
Whenever I have had work done on my car.
I always say if you break something then please tell me and I can get it repaired.
That’s the main reason that I now use unit 20.
Astrosquirrel
Post by Astrosquirrel » Sun Nov 06, 2022 3:52 pm
steve2003rs6 wrote:Had a few jobs done locally and they have broken stuff and not told me.
Yeah I know. Its unfortunate. It's one of the reasons I'm doing many jobs myself. That way I know who broke it i.e me, most of the time Image
So far I've found things either broken or simply not properly done. The PS pump failed because the cooler lines were leaking (and I didn't fix it fast enough)... Then I found someone had used the wrong type of clamps on them. Image
Astrosquirrel
Post by Astrosquirrel » Sun Nov 06, 2022 6:39 pm
So today was a clean day Image
Wheel archers will be done later. Today the suspension was priority.
Post by Shoppinit » Sun Nov 06, 2022 7:33 pm
Shiny suspension. Noice.
Looks like your IC are leaking though.
Astrosquirrel
Post by Astrosquirrel » Sun Nov 06, 2022 7:44 pm
Shoppinit wrote:Shiny suspension. Noice.
Yeah they probably are. I will know for sure now that I cleaned them and there isn't any grease or oil being flinged about. I've a couple spares. I'll see if I can find a regurbisher.
Astrosquirrel
Post by Astrosquirrel » Sun Nov 20, 2022 11:59 am
Answer the question "Do I need to remove the shock assembly to remove the upper control arms?" the answer's no, no I didn't.
Suspension and wheel well cleaned up. Same on the other side
Before shot. Both sides where the same. On the right, grease from the drive shaft boot, on the left oil from the power steering.
Starting reassembly. (with whatever little time I have Image)
Post by Shoppinit » Sun Nov 20, 2022 1:02 pm
I do like a nice clean undercarriage. :)
Astrosquirrel
Post by Astrosquirrel » Sat Nov 26, 2022 1:17 pm
Same here. It was hard work but well worth it.
... On another note, can't find engine mounts within reasonable time. Need the car back on the ground soon. I've rewelded the sensor to the mount but I doubt that's going to work well.
I will put that job for later, that's assuming the engine mounts won't throw the engine management light. Right?
Post by Shoppinit » Sat Nov 26, 2022 1:37 pm
I think I remember seeing some on Autodoc.
They do throw a check engine light, annoyingly. You could keep the old one plugged in - presumably it wasn't giving errors.
Users browsing this forum: Google [Bot], Google Adsense [Bot], srichards and 107 guests
