Phatbox volume
Dippy
Phatbox volume
Post by Dippy » Thu Feb 09, 2006 1:06 pm
My Phatbox is quieter than the radio. I can't see how I can adjust the level so that they are similar for the same volume setting. Can anyone help?
2001 Silver S4 Avant
shineydave
RE: Phatbox volume
Post by shineydave » Thu Feb 09, 2006 7:38 pm
try this
turn on the nav and select the phatnoise
press mode
select volume setup
you now have the choice of selecting either "last" or "change", think mine is on "last" this should bring your volume on at the last selected volume level. as far as i can tell "change" changes the volume back to a default setting so you don't blast your ears if you turned the nav off at a high volume.
Return to “Electrical”
