What's this?
5.0 V10 50v biturbo - 571 bhp
Imola_Sid
What's this?
Post by Imola_Sid » Fri Sep 16, 2022 11:01 am
Found this is in the glovebox.
I thought it was a phone/a2dp connector but not finding anything on my phone when searching Bluetooth.
Any ideas?
Jim Haseltine
Re: What's this?
Post by Jim Haseltine » Fri Sep 16, 2022 12:03 pm
Would have been my first guess. Have you checked the MMI media section to see if there are multiple sources listed?
Imola_Sid
Re: What's this?
Post by Imola_Sid » Fri Sep 16, 2022 12:43 pm
Yup, has the following -
Imola_Sid
Re: What's this?
Post by Imola_Sid » Fri Sep 16, 2022 12:49 pm
This comes up but doesn't connect.
tom4motion
Re: What's this?
Post by tom4motion » Wed Sep 21, 2022 8:39 pm
I had one similar and needed a power source via the USB to work.
2006 RS4 Avant, Sprint blue, Buckets, Carbon trim, black optics, MRC stage 2 and Milltek non res valve'd. SOLD
2008 RS6 Avant, Sepang Blue, APR stage 1
Doug_RS6
Re: What's this?
Post by Doug_RS6 » Thu Sep 22, 2022 4:43 pm
100% will need usb power on 2g mmi system. I fitted a USB port in the glove box
Imola_Sid
Re: What's this?
Post by Imola_Sid » Fri Sep 23, 2022 8:13 pm
Thanks for the replies. Anyway to power it without having cables exposed?
Imola_Sid
Re: What's this?
Post by Imola_Sid » Fri Sep 23, 2022 8:55 pm
How did you do this mate?
IanH755
Re: What's this?
Post by IanH755 » Sat Sep 24, 2022 8:46 am
I would test this device first as the USB powered Bluetooth device I tried (which looks like yours does) sounded absolutely awful when I tried streaming any music over it. It only came through the left speakers, the volume was very low and it sounded not far off an older AM Radio rather than a nice modern Spotify stream so I'm 100% sure I had a "bad" unit which, being made of Chinese-ium, could be a common theme if it's been left unpowered in your car.
Doug_RS6
Re: What's this?
Post by Doug_RS6 » Sat Sep 24, 2022 12:29 pm
Bought a cheap usp socket. Removed the glovebox and drilled a hole in the side to but the usb socket through. Then connected it to a power source. Think I tapped into something like the glovebox light. Originally soldered it but have since switched it out for a connector as when soldered it technically meant the glove box was permanently attached as the wires couldn't be disconnected.
Imola_Sid
Re: What's this?
Post by Imola_Sid » Sun Sep 25, 2022 7:56 pm
Thanks guys!
Users browsing this forum: Google [Bot], Jim Haseltine and 64 guests
