ALternator/generator
5.0 V10 50v biturbo - 571 bhp
Charmie86
Post by Charmie86 » Wed Jul 13, 2022 3:43 pm
HI eveyone had a new alternator fitted a couple months ago and iam getting no communication and partail customer cut off now, ive check the blue wire etc and a new battery. the question is does anybody know if there are different variants of the alternator on our cars with the internals being different to cause these problems. these onlt appreared after the new alternator was fitted
cheers
Paul
VaudiGR
Re: ALternator/generator
Post by VaudiGR » Wed Jul 13, 2022 5:02 pm
What do you mean exactly?
As I'm about to change the alternator as well, you can only buy one code alternator for our cars that is available from the dealers.
Sent from my SM-S908B using Tapatalk
Charmie86
Post by Charmie86 » Wed Jul 13, 2022 10:06 pm
Hi that’s what I was asking I think mine was sourced from a local suppler. Looking at pictures in google the r8 one looks identical and also a few other water-cooled alternators. Could the r8, v10 diesel one fit our cars but have different internals to give me fault codes of no communication to generator and partial customer cut off.
Iam trying to figure out why after the the new alternator was fitted Iam getting these fault codes. I have checked the blue wire to the bem for continuity and that’s fine. I have fitted and coded a new battery also
Paul
Charmie86
Post by Charmie86 » Mon Nov 28, 2022 2:28 pm
i really dont know what to make of that last comment, so do other v10 alternators fit the c6
IanH755
Post by IanH755 » Mon Nov 28, 2022 7:58 pm
That comment is from a Spam bot selling/advertising random tat, I've reported it but the mods haven't removed them yet.
As VaudiGR mentioned, there is only one alternator which you can use for the RS6, any other alternator from a R8, S6 V10 etc, despite all being 190A Hitachi ones, are not designed for the RS6 as they have different part numbers. Maybe they will physically fit the V10 block but there maybe other issues which make them RS6 specific which I don't know about.
Charmie86
Post by Charmie86 » Mon Nov 28, 2022 8:11 pm
Thanks Ian
That’s why I wondering cause I have the two fault codes as mentioned which I didn’t have with the old alternator. Could they have different electronic boards in each of them if they did fit
Paul
zex
Post by zex » Wed Jul 12, 2023 7:37 pm
What is the right part number for our alternator?
Is there some kind of written procedure for replacement?
IanH755
Post by IanH755 » Wed Jul 12, 2023 8:03 pm
Part Number is 07L903015C and a procedure can be found online here - https://www.kolhosniki.ru/elsaonline&ve ... sl--3#file
As a reminder it's water cooled so you'll need more coolant afterwards.
zex
Post by zex » Thu Jul 13, 2023 10:05 am
Thanks Ian :beerchug:
Jim Haseltine
Post by Jim Haseltine » Thu Jul 13, 2023 2:40 pm
Also available as a core exchange under part number 07L903015CX.
alex.r
Post by alex.r » Sat Jul 22, 2023 11:36 am
Hi everyone, my alternator gave up on me yesterday while on vacation... so tough times to get a part, however one of the workshops, found 07L903015DX,
so wondering if anyone might know the difference between 07L903015C and 07L903015D which according to partslink was fitted on these cars.
Best regards,
Alex R.
VaudiGR
Post by VaudiGR » Sat Jul 22, 2023 11:47 am
According to the parts catalogue it should work fine.
Sent from my SM-S918B using Tapatalk
alex.r
Post by alex.r » Sat Jul 22, 2023 6:56 pm
Thanks VaudiGR!
Do you also know it can be done without removing the front/radiator(s) ? Also any guesstimates on the time required.
Asking because I've seen a bit of hesitation on all workshops to touch the car, so I might endup getting my hands dirty.
/Alex
VaudiGR
Post by VaudiGR » Sun Jul 23, 2023 7:47 am
My mechanic did it by undoing some bolts of the radiators without removing them. You still have to drain the coolant and some gearbox oil. But he didn't have to take the front end completely off
ruedisrs6
Post by ruedisrs6 » Sun Jul 30, 2023 8:06 am
I replaced mine recently. No need to drain gearbox oil. Congrats to the mechanic who was able to remove the long bolts without removing the radiators. I was not able to remove the coolant connection pipe without putting the main radiator and the fans aside. But was quite a straightforward procedure which simply takes some time.
Users browsing this forum: No registered users and 11 guests
