I’m pretty sure that this is water from the ac unit as I’ve only noticed it when hot outside and the ac blasting but wanting to check as my rs6 is new to me
Seems to be dripping towards the rear of the engine bay on the passenger side and seems to be sometimes dripping onto something hot as it sizzles.
Is this likely to be water from the ac unit or some kind of drainage pipe in this location?
Hoping the answer is yes! It’s not a massive puddle but enough for me to notice
Water puddle under the car
Re: Water puddle under the car
Have you done the taste test?
AC drain is located at the front of the trans tunnel pretty much where you have described. Pipe is behind the heat shield so might be coming through one of the shield's mounting holes onto the exhaust.
I should taste to see if it’s water??
No please dont... It was a joke.
Well I actually took you seriously because loads of other people recommend doing the same lol!?
- 1st Gear
taste test always an easy winner, will tell you if its coolant or oil, obviously don't put a lot in and swallow lol
Users browsing this forum: No registered users and 89 guests
