Tyre to Arch gap different
anditsoundslikebells
Post by anditsoundslikebells » Mon Jun 13, 2022 8:29 pm
I finally have the cars set up dialled as I wanted. It's low, just right for me, it doesn't rub, it's firm but not too firm (Bilstein standard settings for now), there is some camber, no rubbing in the arch anywhere.
I'll put some pics up this weekend when I take it out for a drive.
One problem though. Although the suspensions is all new, set up symetrically, there is significant variation in the position of the face of the rim/tyre in relation to the arch:
FR 23mm
FL 11mm
RR 11mm
RL 20mm
I'm pretty sure the FR & RL have been dinged and repaired somewhere in the cars history. I'd like to bring down the variation if possible.
Although none are rubbing the FL is close, while the FR is way off. The RR sits perfectly in the arch, while the RL doens't. The RL is not really visible as a different though.
I'm trying to work out what options I have:
1) Live with it
2) Have the arches reshaped and resprayed (too much cash)
3) Is there much adjustment of subframes in our cars? My normal garage thought they would check subframe alignment when the weighting/alignment was done, but it was a quick job and no time spent to figure it out.
4) Run spacers on the wheels that need pushing out. I read about this being done on some 964s as they asymetrical arches sometimes. Doesn't sound great. If I won't notice anything, its the easiest solution. Considering this.
I'll add some pictures over the weekend.
How are everyone elses arches?
RS6 C5 Avant 2002 Daytona Grey
TTH 620 - Wagner IC - OC.T 200cell&downpipes - DW400 pump - 034 TCU chip - FIS - B16 PSS9 - 034 control arms - H&R ARB - OZ Superturismo
steve2003rs6
Re: Tyre to Arch gap different
Post by steve2003rs6 » Tue Jun 14, 2022 9:49 am
That’s weird. Mine are set up with 1 inch approx all round.
Which was done when I had the new suspension installed at unit 20.
A bit high for some but I like it.
Post by Shoppinit » Tue Jun 14, 2022 9:57 am
That's really weird.
Yes, there is an adjusment on the subframe. There are a series of holes about 20mm diameter that need to line up. If they don't then your subframe has been put on wrong.
Post by anditsoundslikebells » Tue Jun 14, 2022 10:39 am
just to be clear, these are horizontal distances, not height. I have 9.5" ET40 rims so that explains the closeness of the rims to the arch.
i'll put some pictures up and the difference is clearly visible.
does this apply to front and rear subframes?
does anyone know of a resource i can look at to understand where I am looking for the subframe alignment?
anyone know how much movement there is left to right? I'd need 4.5mm but that sounds like a lot.
Post by anditsoundslikebells » Tue Jun 14, 2022 11:01 am
after a bit of digging I came across this:
https://www.audizine.com/forum/showthre ... -Alignment
is this the kind of job I'm looking at?
Post by Shoppinit » Tue Jun 14, 2022 11:09 am
Good find. Pretty much your exact issue. You can see the large holes I referred to by the left yellow arrow.
Post by anditsoundslikebells » Tue Jun 14, 2022 11:26 am
I'll have a proper look and see where I get to.
The link is for a B7 A4 but I assume the principle is the same.
They talk about a 5mm adjustment. That would fix all my probelms.
steve2003rs6
Post by steve2003rs6 » Tue Jun 14, 2022 11:35 am
Paranoia now kicking in. I will have to go and measure mine now. Thank you Alex !
Mɐʇʇ
Post by Mɐʇʇ » Tue Jun 14, 2022 12:03 pm
I'm not going to look. :mrgreen:
srichards
Post by srichards » Tue Jun 14, 2022 4:09 pm
Neither am I!
Post by Shoppinit » Tue Jun 14, 2022 4:12 pm
Same
steve2003rs6
Post by steve2003rs6 » Tue Jun 14, 2022 5:46 pm
Must admit I had to LOOK 👀
Although I didn’t actually measure them.
They do appear to be pretty central In the wheel arch.
PHEW I was dreading another job to add to the list.
Foxmeister
Post by Foxmeister » Wed Jun 15, 2022 8:20 am
Mine are in the arch, im happy ;)
Post by anditsoundslikebells » Fri Jun 17, 2022 1:15 pm
Post by anditsoundslikebells » Fri Jun 17, 2022 1:16 pm
Here is the current set up.
You can just about see this difference:
FR 23mm
FL 11mm
RR 11mm
RL 20mm
Users browsing this forum: B_O_N_K, Cunningstunt and 119 guests
