Random flat battery
Random flat battery
Hi all
Got back to car Friday afternoon to go home, and car wouldn’t start. Dials did their thing, but nothing!! Battery is less than a year old, but had noticed, not sure if related, keyless entry isn’t as good as it used to be. Keys both have new batteries in.
A friend had mentioned why I don’t put key into slot ever now and again, didn’t think it needs to as keyless!!
Any ideas would be good
P.s. want is adaptive headlight fault?? This comes up but not all the time
Thanks all
Thanks all
Re: Random flat battery
Get a battery test done first to confirm the battery is still ok. Get the charging checked to make sure the battery is being supplied the correct voltage from the alternator, then look at current drain test to see which modules are still awake after locking and what the current draw is. Max should be 50mA, anymore and it will kill your battery in days
RS6 Performance Ascari blue, Carbon Ceramics, Akrapovic, H&R Anti Roll bars
@morski have only done a voltage check with engine off and idling, 12.26v and 14.65v. Gonna get it booked in soon to have it looked over and ask them to check everything over
Those voltages seem fine. If you have a multimeter you can do a current draw check yourself. The parasitic drain test is where its time consuming and tedious
When the battery is down on voltage, it throws up all sorts of random dash warnings/ faults, many of which are fictitious, and the system is fine when the battery is charged fully, or replaced.
When my battery was dying, I got a suspension fault warning. Apparantly, if the car detects a low battery voltage, then it shuts down certain systems until normal battery voltage is restored, hence the random dash warning lights.
Some have dismissed this point as unnecessary, but the correct type of AGM battey should be fitted on replacement, AND it should be coded to the car from the outset, otherwise certain electrical don't work quite as they should. I can't give specifics about this, or the specific issues it can cause, but I'm just quoting the Audi technician (who is very experienced and I've had dealing with for years - before any criticism is levelled at Audi servicing etc) who replaced my battery under the manufacturers warranty a few years ago, so my memory on the reasons he gave has faded somewhat since....
Was this resolved? What was the fault?
Not yet, but probable cause may have been my dash cam not turning itself off!! However it’s currently sat in a garage to have some faults looked at and hopefully fix
will let you know what the outcome is
Got call from garage today, all fine. Headlight fault was a knackered sensor which needed replacing
Users browsing this forum: No registered users and 85 guests
