Coilovers
Re: Coilovers
Post by Shoppinit » Wed Feb 02, 2022 4:27 pm
Shoppinit wrote:
Wed Feb 02, 2022 10:20 am
I hate suspension work for this reason. Nothing difficult but everything heavy, dirty, seized and awkward.
ChrisA
Re: Coilovers
Post by ChrisA » Wed Feb 02, 2022 4:39 pm
Mɐʇʇ
Re: Coilovers
Post by Mɐʇʇ » Wed Feb 02, 2022 5:23 pm
Re: Coilovers
Post by Shoppinit » Wed Feb 02, 2022 5:30 pm
How would you stop the shaft rotating?
I've got a DTD154. I wonder if I can get a 1/2" drive for it.
Mɐʇʇ
Re: Coilovers
Post by Mɐʇʇ » Wed Feb 02, 2022 5:40 pm
I wouldn't just bang it on and run it - I'd give it a squirt and expect the nut to come off PDQ. TBH, you could probably just hold the shaft in your hand, that'd likely be enough resistance.
Unless the nut is truly and properly seized on, then you need to get more creative.
ChrisA
Re: Coilovers
Post by ChrisA » Wed Feb 02, 2022 6:01 pm
Well that was interesting. I ran it up to a mate of mine who works in a garage. He stuck an impact driver on it and it came straight off without needing to hold the shaft. Worth remembering that little trick. 👍
Thanks Matt. 👊
Mɐʇʇ
Re: Coilovers
Post by Mɐʇʇ » Wed Feb 02, 2022 6:12 pm
:thumbs:
steve2003rs6
Re: Coilovers
Post by steve2003rs6 » Wed Feb 02, 2022 7:22 pm
That’s a problem with diy. You often need a shed load of the right tools.
Then limited access if you are working off axle stands.
Then your labour time. Often ten times longer without the above facilities.
Having said that. I do understand the gratification you get from doing a good job.
Mɐʇʇ
Re: Coilovers
Post by Mɐʇʇ » Wed Feb 02, 2022 7:30 pm
For me, it's as much fun doing the work as it is owning the thing. Have 30 years of collecting tools I just use once so far, hope to get another 30, but we'll have to see.
This was last weekends job, which was quite enjoyable - new bracket for the landrover (they don't make those brackets that you can buy) and started removing the bulkhead to make more space inside it too.
steve2003rs6
Re: Coilovers
Post by steve2003rs6 » Wed Feb 02, 2022 11:10 pm
Really nice work Matt
ChrisA
Re: Coilovers
Post by ChrisA » Thu Feb 03, 2022 12:51 pm
Do I need to make a note of which coilover when on which side of the car, which spring when on which coilover and what way round the springs went?
Re: Coilovers
Post by Shoppinit » Thu Feb 03, 2022 12:51 pm
Can't think that it would matter, but I would do that as a matter of course.
steve2003rs6
Re: Coilovers
Post by steve2003rs6 » Thu Feb 03, 2022 1:30 pm
Chris. Having gone to that trouble. I would find a grit blast cabinet and then give them a good paint job.
Nice work mate.
Mɐʇʇ
Re: Coilovers
Post by Mɐʇʇ » Thu Feb 03, 2022 1:48 pm
I'm with Steve - you want them to go back on looking smart. I got all my springs & steel suspension arms (rear) powdercoated.
ChrisA
Re: Coilovers
Post by ChrisA » Thu Feb 03, 2022 1:54 pm
Yes, already booked in for PC. I love getting things pc and plated. 😍
Users browsing this forum: Bing [Bot], srichards and 109 guests
