Audi B7 RS4 For Sale - Clean with extensive history
Rsshine
Post by Rsshine » Tue Feb 01, 2022 12:28 pm
The B7 RS4 is last of the manual naturally aspirated V8. This particular example is stunning and has been well looked by current and previous owners. If you’ve done your research you’ll know there a few common issues that are faced with the B7 RS4 over time. This example has had them addressed as per the work carried out description below. Subtle mods provide an OEM Plus look with the 20” Le Mans alloys and Bilstein suspension. All maintenance services carried out by Audi, MRC and Unit 20 who are renowned as Audi specialist. Most recent service completed in Jan ‘22. Still has the noted kick at approximately 5500 RPM in Sport Mode.
95k, 6 previous owners (previous owner was an Audi enthusiast)
Last service at Audi in Jan ‘22 and MOT until Jan ‘23
£21,995
Factory Options:
Carbon fibre trim, Flat bottom steering wheel, desirable heated recaro bucket seats, black headlining, black optics, factory tints, SS+ suspension (replaced by B14’s), tech pack (auto lights/wipers), glovebox cd player, adaptive bi xenon headlights, RNSE with aux, rear door blinds
Work Carried out:
All new lemforder front arms and arb links
New complete manifold @ audi and first carbon clean
Clutch, flywheel, slave, robnic hose
4 new lower door blades
All fluids replaced inc. diff and gearbox oils
Starter motor & 5 relays + clutch switches x2
Most cv boots inner and outer replaced
Track rods and ends replaced & tracking done at Audi
Steering wheel buttons/trim/badge
New scuttle
New brake duct in undertray
Varta AGM battery
Pads front and rear
New top mounts
New TPMS sensors & TPMS antenna
Second carbon clean 05/20 inc new oil, filter, gaskets/o rings, 1 way valve
Aux rad
Lambda sensor
OEM Valeo rear wiper motor
Modifications:
MRC Stage 2 remap 427ps
ECS H pipe
Gutted precats (secondary)
20” Audi S5 Le Mans double spoke alloys with Michelin Pilot Sport 4S tyres
8mm h&r hubcentric spacers
H&R longer bolts inc. locking bolt
Bilstein B14 Coilovers
HEL braided brake hoses
Genuine Audi jet & mist washers jets
Genuine Audi LED number plate lights
All 4 engine mounts replaced with 034 motorsport street density mounts
H&R DRC pipe blanks
Powerflex ARB clamp bushes
PowerFlex top arm bushes (camber adjustable)
New front headlight lens
Pioneer SPH-DA250DAB stereo with DAB & Apple CarPlay/AndroidAuto.
Service History:
May 2008 - 11714 - Coulsdon Audi
Feb 2010 - 27458 - Wimbledon Audi
Apr 2011 - 36998 - Audi
May 2013 - 55277 - Bexley Audi
Feb 2015 - 65197 - Tunbridge Wells Audi
Nov 2016 - 74776 - MRC Tuning
Dec 2017 - 80551 - MRC Tuning
Dec 2018 - 86192 - Unit 20
Dec 2019 - 91243 - Unit 20
Dec 2020 - 94315 - Audi Watford
Jan 2022 - 94893 - Audi Watford
No tire kickers or test pilots. Only contact if you are serious. Image
Rsshine
Re: Audi B7 RS4 For Sale - Clean with extensive history
Post by Rsshine » Tue Feb 01, 2022 12:31 pm
Rsshine
Post by Rsshine » Sat Feb 05, 2022 2:58 pm
Cars sold.
