Gearbox issues C7.5 PE - Stage2
joshviiv
Post by joshviiv » Thu Jan 13, 2022 4:45 am
Gents, first time RS owner - I got into a 2017 RS6 performance, here in australia they are a little more rare than europe!
This is my dream car, so i got straight into getting it to my spec - i've had brondex catless downpipes installed along with the evolve technik stage 2 tune.
Took the car to the drag strip - dynamic mode on, ESC totally off, brake boost launch. The car would get out of the hole fast, and then when i tried to click second gear, the gearbox wouldnt change. It went immediately into limp mode - i drove the length of the track in first gear, switched car off, switched back on - gearbox now works again.
However i've noticed, when the car is in Drive (auto), when taking off from a complete stop there will be almost a lurch in the gearbox immediately as it starts to roll away. If you take off fast, its very very noticeable. Its almost like the clutches arent engaging early enough and then suddenly it'll lurch forward. I also noticed that when the car is rolling, if you put your foot down to overtake or something, the car will BANG back down into gear, its not smooth at all like it was pre drag strip incident.
The other thing to note, is that the car drives perfectly smooth in manual mode. No lurch from standstill, changes up and down beautifully.
Anyone experienced something similar? Any advice on what i need to be looking at?
First steps for me will be to reset the tcu back to factory (i read that the gearbox learns? im thinking maybe its out of whack somehow). And i also intend to put a TCU tune in it to see if that makes a difference.
I understand issues like this are very hard to diagnose online - but its a fairly obvious issue and if anyones experienced it before i'd love to hear what you found.
cheers!
J
joshviiv
Re: Gearbox issues C7.5 PE - Stage2
Post by joshviiv » Thu Jan 13, 2022 4:52 am
thread useless without pics etc... ;)
JoolsBerko
Post by JoolsBerko » Thu Jan 13, 2022 9:38 am
Unfortunately well beyond my level of expertise (might be the auto-gearbox synching is out due to the additional power the Stage 2 has - but that's just a wild guess based on it working fine under manual gear selection), but there's some great people on here who will be able to offer really top notch advice. So just wanted to say "G'day, well done on the Ashes win, and tell Djokovic to piss off!". Car looks a beauty, you deserve to feel very proud of her.
Regards
Jools
2014 Panther Black RS6 with Black Wheels & Stealth Pack
Previous recent notable inclusions: 2013 TTRS, 2009 A3 Black Edition, and 1997 Vauxhall Corsa (a truly great car when times were very hard - hence the mention)
In years gone by: MR2 Turbos, Supras, Skylines, RX7's
HDPete
Post by HDPete » Thu Jan 13, 2022 10:46 am
Sounds software / map related to me. The two not quite synching
joshviiv
Post by joshviiv » Fri Jan 14, 2022 1:06 am
Thanks for the responses guys - sounds like you're onto something!
innercry666
Post by innercry666 » Fri Jan 14, 2022 5:05 pm
Has the gearbox software been updated to take the increase in torque from the engine map?
Admittedly I don't have any experience of mapping these cars but it does sound as if the gearbox is not happy with the extra torque particularly when hitting it hard. Sounds like the torque limit needs to be raised in the gearbox map...
RS6 PE - Current
RS4 (B8.5) 2015 - Sold
A4 3.0 TDI Quattro BE Avant - Gone
Focus ST170 - Garaged
rs64u
Post by rs64u » Mon Jan 24, 2022 8:42 am
My gearbox just fxxk up
, it was making lots of noise when accelerating .
Anyone knows how much it usually cost !
I have quoted silly money but am
Getting it fixed
markjo77
Post by markjo77 » Mon Jan 24, 2022 9:07 am
Easy 10k+ if its totally gone...
Tadass910
Post by Tadass910 » Wed Jan 26, 2022 4:52 pm
Strange, those gearbox can handle up to 1000 of torque, something is here not right. Did you bough used car or you bought it new and did stage ?
joshviiv
Post by joshviiv » Thu Jan 27, 2022 1:43 am
The user above sounds like he's having a much worse issue, mine doesnt make noise at all - i'm confident a flash to default and then the TCU tune will fix the problems i'm having. But my car was standard before i took it to stage 2. Unsure what the gentleman above has done to his..
Thanks all for your responses, i'll update the thread once my guys have fiddled with it.
Users browsing this forum: Baidu [Spider] and 36 guests
