As mentioned above the car has no cats.Mɐʇʇ wrote:Looking at the power, seems likely the "stage 2" was to do tweaked/custom tune on the rollers rather than the off the shelf stage 1 "lady map" myself and some others have.
Power looks on a par with a "stage 1", having all the cats still in & stock, I reckon?
New RS6 owner!
Re: New RS6 owner!
Foxmeister
Re: New RS6 owner!
Welcome
FON
Looks a mean one with all the blackness, GRRRRR!!!
How do you find the 15mm spacers, any catching over dips and bumps etc?
FON
Re: New RS6 owner!
Thank youFoxmeister wrote:Welcome
FON
Looks a mean one with all the blackness, GRRRRR!!!![]()
No catching and the car is very low, I may lift it slightly.
Re: New RS6 owner!
Can anybody give me rough dimensions of the badge locations on the front grill and boot? I want to put the rs6 badges back on.
Foxmeister
Re: New RS6 owner!
Excellent, good to know
Do you happen to know which brand they are???
Foxmeister
Re: New RS6 owner!
I’m afraid I don’t but from passed experience I would recommend H&R.Foxmeister wrote:Excellent, good to know
Re: New RS6 owner!
Nice one. One of the nuts is missing on the front badge so need to figure out how to fix that
Re: New RS6 owner!
There’s a clip that goes on the other side of the badge. I need one too. NLA obvs. :-/
If we can get some decent positioning data I’ll put it on the FAQ. Front badge is easy enough from press photos. Rear a bit more tricky.
Re: New RS6 owner!
Yeah rear is going to be a pain.Shoppinit wrote:There’s a clip that goes on the other side of the badge. I need one too. NLA obvs. :-/
This is my front badge, looks like the clip has been ground off
Re: New RS6 owner!
Just been out on a run to the shops and had the PRNDS on the dash and no gears. Then on the way home it was back to normal again. Is this one of the sensors on the gearbox playing up?
Re: New RS6 owner!
Could be the F125 switch. Best attended to quickly as it can cause extra wear on expensive things when they go wrong.
Foxmeister
Re: New RS6 owner!
Quick detail on rear boot badge
Re: New RS6 owner!
That’s brilliant thank youFoxmeister wrote:Quick detail on rear boot badge
Re: New RS6 owner!
I’ll get one ordered up, I’m guessing it’s the controller for changing gears?srichards wrote:Could be the F125 switch. Best attended to quickly as it can cause extra wear on expensive things when they go wrong.
