Error free DRL's
- Silverfox42
Error free DRL's
Hi Folks,
Been searching some old threads for current LED DRL replacements for the standard bulbs, but most links/name manufactures can no longer be found. I replaced my Saloons lights in 2014 but that supplier isn’t around now.
Anyone got a current Error free solution? Is Trups still around?
Previous:
Previous:
Re: Error free DRL's
Recently been through this myself.
Very mixed reviews of error free bulbs especially on Audis.
Ended up getting standard DRL LED's and fitting resistors on a bracket behind the left side headlight.
Seem to work ok - I'll just have to keep an eye on the heat generated by the resistors...
Mike
Mike
EM Tuning do them for the B7. Error free
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Pistolpete2543
Error free for a few months only in my experience, then started flickering & throwing up bulb failure errors. When I pulled them out, there were discoloured with heat. Great looking bulbs when they worked, but not worth my RS4 going up in smoke so I went back to standard DRL bulbs
The ones from EM Tuning? I’ve had mine in nearly 4 years? No issues at all.Pistolpete2543 wrote:Error free for a few months only in my experience, then started flickering & throwing up bulb failure errors. When I pulled them out, there were discoloured with heat. Great looking bulbs when they worked, but not worth my RS4 going up in smoke so I went back to standard DRL bulbs
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Pistolpete2543
[/quote]
[/quote]
Yep, EM Tuning ones.
viewtopic.php?f=35&t=125255&p=859232#p859232
[/quote]
I too have had EM Tuning DRL's in for at least 4 years now, and no issues at all, Trups is the man when it comes to modifying any lighting on these cars, as they do seem to be very sensitive when it comes to which type of lights you choose.
- Silverfox42
I sourced some of Trups DRL replacements from another forum member which worked fine at first, but in the last 3 weeks have been getting intermittent errors from both sides, so swapped back to a bright (blue glass) Xenon bulb which actually works really well, only slightly dimmer than LED's and no errors.
Previous:
Previous:
I've been running Trups LED for three years now with no issues.
Sent from my ONEPLUS A6013 using Tapatalk
Current
'07 - Audi RS4 Avant Daytona Grey
'16 - BMW M135i F20 (LCI)
'53 - Land Rover Range Rover Vogue 4.4 V8
Gone
'02 Audi 8L A3 1.9 TDI (PD)
'03 Subaru Impreza WRX STI
'96 VW Golf VR6
'91 Toyota MR2 NA
'90 Peugeot 205 GTI 1.9
'90 VW Mk2 Golf GTI 8V
Gone
'96 VW Golf VR6
'91 Toyota MR2 NA
I had a set of Trups DRL and they failed, were all discolored and had heat damage after about 2 years.
I got a replacement set, they worked fine for a few months but started throwing errors again.
No visible heat damage this time, but I keep an eye on them and would advise others to do the same.
Sent from my HD1903 using Tapatalk
So my RS4 is back on the road 3 months now and one of the updated Trups DRL has failed, it was throwing errors for a while but fully gone now.
Interested to hear if anyone has any other solution apart from back to standard?
Why not back to standard? Are there known issues with the standard bulb, hence why people move to LEDs
Sorry not to hijack, just interested.
My DLR bulb has blown and melted itself to the housing. Still need to work out a way of getting it out without taking the bumper off!
Just aesthetics really!
The LED just look much better than the halogen and if there was an error free one it would be great.
After a bit of searching and weighing up the options I ended up ordering a new set from Trups/EM Tuning
They have released a V2 earlier this year and in fairness the customer service was top notch so I'll give them a go and report back.
Haha wonder if you'll still get the EMs!
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 165 guests
