How much coolant in total in the system?
4.2 V8 32v FSI - 444 bhp
Scammo1
Post by Scammo1 » Sat Nov 13, 2021 5:35 pm
Noticed a small drip of coolant near the passenger side front wheel.
Car won’t be moving until it goes to a garage for investigation but wanted to know how much coolant is on the whole system in case it loses a lot and I need to top up
johnnydog
Re: How much coolant in total in the system?
Post by johnnydog » Sat Nov 13, 2021 6:51 pm
Why don't you just buy the correct pink antifreeze for your car (buy decent quality antifreeze, or genuine Audi, bearing in mind not all antifreeze is the same quality) then dilute some to the correct strength (50%?) in a separate container, so you have it at hand if needed. If the cooling system is suddenly losing a lot of coolant, I wouldn't consider driving it very far anyway until the reason is fixed. Soft water is ok in the mix, but if you are in a hard water area, then I would use use distilled water to dilute it.
Scammo1
Post by Scammo1 » Sat Nov 13, 2021 7:13 pm
I have bought 5 litres of the right red coolant. Just want to be sure that’s enough if it keeps leaking over the weekend
johnnydog
Post by johnnydog » Sat Nov 13, 2021 10:39 pm
At a 50% mixture, you will have 9 or 10 litres (depending on container quantity), which should be more than enough for topping up, even with a 'small' coolant loss. From memory, I think 9 litres diluted is required for a coolant change.
Users browsing this forum: No registered users and 85 guests
