In garage now : hub centric h&r 8mm spacers not fitting OZ
anditsoundslikebells
Re: In garage now : hub centric h&r 8mm spacers not fitting OZ
Post by anditsoundslikebells » Sat Oct 30, 2021 6:57 pm
So, the spacrs fit on the OEM no worries.
and the OZ fit on the hubs no worries.
I'll have to have a more thorough comparison of the spacer and the hub. maybe there is a slight difference in the profile.
As shopp said, both have a 5mm lip so I'm unsure what else could be there.
Myself and two others have fitted the OZ rims to the hubs with no obvious issue.
All a bit weird.
RS6 C5 Avant 2002 Daytona Grey
TTH 620 - Wagner IC - OC.T 200cell&downpipes - DW400 pump - 034 TCU chip - FIS - B16 PSS9 - 034 control arms - H&R ARB - OZ Superturismo
Post by Shoppinit » Mon Nov 01, 2021 1:50 pm
I think it's the big conical chamfer. The OE wheel has a big negative chamfer so the spacer can fit inside it OK, but maybe the OZ doesn't.
Nige_RS4
Post by Nige_RS4 » Mon Nov 01, 2021 2:21 pm
Ask OZ if they have any different spigots for the C5
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
Post by Shoppinit » Mon Nov 01, 2021 2:22 pm
How are the spigots located in the wheel? Could they not be pushed in far enough / too much?
Post by anditsoundslikebells » Mon Nov 01, 2021 8:56 pm
I was thinking the same. likely an issue with the chamfer, I did wonder if the spigot can go in further.
I'll check both and write back.
Users browsing this forum: philS2 and 95 guests
