Starter motor fuse
4.2 V8 32v FSI - 444 bhp
Rs4nutter
Starter motor fuse
Post by Rs4nutter » Sun Aug 29, 2021 9:04 pm
Evening all
Have got a kill switch to fit onto starter motor via fuse, question is where is it located, and what amp fuse is it.
Kit supplied only has a 5amp fuse but think it to small
Have looked in owners manual, says 40amp
HPsauce
Re: Starter motor fuse
Post by HPsauce » Sun Aug 29, 2021 9:13 pm
A starter motor wouldn't normally have a fuse and 5A would be hilarious, as would 40! They can draw literally hundreds of amps, look at the CCA rating on a battery for a clue.
Hopefully you're looking to link into the starter relay circuit...…..
The starter relay is typically rated at 30 or 40 amps to cover peaks, though typically about 10A is needed to "hold" the starter solenoid.
Rs4nutter
Post by Rs4nutter » Fri Sep 24, 2021 12:16 pm
Afternoon all
Have tried to connect a cut off type switch so car won’t start, fitted all works well, however once started car it comes up with tpms and sports diff warning lights.
Why have these come on? And I thought only the starter motor relay was the only thing on this 40amp fuse!!
Any ideas?
Thanks all
Rusty Racer
Post by Rusty Racer » Sun Sep 26, 2021 5:55 pm
Not sure but I think these are battery related issues
2018 RS4 B9 Carbon Edition
2014 RS4 B8
Rs4nutter
Post by Rs4nutter » Sun Sep 26, 2021 6:03 pm
Evening
Thanks Rusty Racer, put new battery on couple of months ago, but didn’t code it to car, as was told should need to as it’s not an agm battery?
May need to code it?
Users browsing this forum: Brooner and 99 guests
